Re: problems in using a custom IApplication class : AssertionFailedException [message #330570 is a reply to message #330558] |
Mon, 04 August 2008 02:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: lifesting.gmail.com
Hi, Jeevan. Workbench is a simple IApplication, it includes basic UI,
Workspace(resource manager), help, retarget actions, search and more....
if any of your code has referenced any function supplied by workbench
directly or indirectly, your application must be failed.
From the exception stack, it seemed that you used Redo/Undo, but the
application which replaced Workbench didn't provide complete
OperationHistory (lack Operation Context) as Workbench configured.
Jeevan wrote:
> I recently changed the Run setting for my application to use a custom
> IApplication class instead of org.eclispe.ui.ide.workbench. Everything
> used to work fine earlier, but now I get an AssertionFailedException
> (detailed error message at end of mail)
> I have checked the list plugins included and they are the same as earlier.
> Infact everything remains the same except the change in the main class.
> Is there something I am missing. I did see many users complaining about
> a similar exception, but no solutions.
> Any help would be appreciated.
> Thanks in advance
> -Jeevan
> org.eclipse.core.runtime.AssertionFailedException: null argument:
> at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:84)
> at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:72)
> at
> org.eclipse.core.commands.operations.AbstractOperation.hasCo ntext(AbstractOperation.java:150)
> at
> org.eclipse.ui.operations.OperationHistoryActionHandler$Hist oryListener.historyNotification(OperationHistoryActionHandle r.java:179)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory $2.run(DefaultOperationHistory.java:929)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .notifyListeners(DefaultOperationHistory.java:918)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .notifyAboutToExecute(DefaultOperationHistory.java:941)
> at
> org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:508)
> at
> com.siemens.med.cad.kmt.dkc.diagram.part.RemindNewProjectWiz ard$1.run(CustomProjectWizard.java:165)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
> at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
> at
> com.siemens.med.cad.kmt.dkc.diagram.part.RemindNewProjectWiz ard.performFinish(CustomProjectWizard.java:195)
> at
> org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
> at
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:618)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
> at org.eclipse.jface.window.Window.open(Window.java:796)
> at
> org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcutAction.java:135)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> com.siemens.med.cad.kmt.dkc.diagram.application.RemindApplic ation.start(CustomApplication.java:41)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
FUDForum. Page generated in 0.03053 seconds
