Home » Eclipse Projects » Eclipse Platform » Programmatically locate file in Project?
Programmatically locate file in Project? [message #330502] Wed, 30 July 2008 11:06 Go to next message
Given an IProject A and a file name B, is there any facility available
that can be used to determine whether file B is contained in project A?
My goal is to be able to determine whether a file belongs to a project
without doing a file search. Thanks.
- Ryan
Re: Programmatically locate file in Project? [message #330506 is a reply to message #330502] Wed, 30 July 2008 12:08 Go to previous messageGo to next message
You can use a IResourceVisitor to browse thru the files in the project
and determine whether its available or not.
- Prakash
www.eclipse-tips.com
> - Ryan
Re: Programmatically locate file in Project? [message #330511 is a reply to message #330506] Wed, 30 July 2008 14:40 Go to previous messageGo to next message
Thanks for the reply...this can work if all I have is a filename, like
"test.h", and not a full path, like "/this/is/the/actual/location/test.h"?
- Ryan
Re: Programmatically locate file in Project? [message #330520 is a reply to message #330511] Thu, 31 July 2008 00:51 Go to previous message
Yes. You should call project.accept(resourceVisitor); It will call the
visit method for every resource (assuming you have returning true for
its parent) Just check the java docs. It should help a lot
- Prakash
> - Ryan
Previous Topic:Building Update Site with platform specific fragments
Next Topic:Progress bar in wizard
Current Time: Fri Apr 25 19:49:42 EDT 2025
Powered by FUDForum. Page generated in 0.07269 seconds
