Home » Eclipse Projects » Eclipse Platform » Why I can't set breakpoint on internal class when debugging?
Why I can't set breakpoint on internal class when debugging? [message #330461] Tue, 29 July 2008 11:44 Go to next message
Originally posted by: lifesting.gmail.com
for example, classes in org.eclipse.ui.interanl, I even can't get a
outline in outline view. by the way, I use Eclipse 3.4 and read/write
code through Plug-in Development perspective.
Thanks a lot!
Re: Why I can't set breakpoint on internal class when debugging? [message #330499 is a reply to message #330461] Wed, 30 July 2008 10:21 Go to previous message
What I have experienced is that the breakpoint is set but the GUI doesn't
show it clearly.
Add a comment if applicable to this bug I have opened recently:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242229
> Thanks a lot!
Previous Topic:eclipse launch framework
Next Topic:Re: Listening for a page change
Current Time: Fri Mar 14 01:42:05 EDT 2025
Powered by FUDForum. Page generated in 0.02967 seconds
