Home » Archived » BIRT » crosstab refresh data cube
crosstab refresh data cube [message #330415] Fri, 25 January 2008 17:17 Go to next message
Originally posted by: nemer.web.de
when i use a crosstab i'm looking for a solution to refresh the data
cube to get the latets data. I allways get the older data but not the
latest. I deployed the report, tried preview and the viewer, all the
same. How can i do it?
regards
nickes
Re: crosstab refresh data cube [message #339824 is a reply to message #330415] Sat, 26 January 2008 12:43 Go to previous messageGo to next message
Tianli Zhang is currently offline Tianli ZhangFriend
Hi nickes,
This is a known issue when refresh data from cube in deploy environment.
See bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=208511. It has been
fixed in BIRT2.2.2. In your build, the only solution is restart the
server. So I suggest you to update the build.
Tianli
Re: crosstab refresh data cube [message #345083 is a reply to message #339824] Sat, 26 January 2008 19:07 Go to previous message
Thanks!
nickes
Re: crosstab refresh data cube [message #345158 is a reply to message #339824] Sat, 26 January 2008 19:07 Go to previous message
Thanks!
nickes
Re: crosstab refresh data cube [message #349146 is a reply to message #339824] Sat, 26 January 2008 19:07 Go to previous message
Thanks!
nickes
Re: crosstab refresh data cube [message #349222 is a reply to message #339824] Sat, 26 January 2008 19:07 Go to previous message
Thanks!
nickes
Previous Topic:crosstab refresh data cube
Next Topic:crosstab refresh data cube
Current Time: Thu Dec 26 13:51:50 GMT 2024
Powered by FUDForum. Page generated in 0.03870 seconds
