Home » Eclipse Projects » Eclipse Platform » JFace snippet doesn't compile
JFace snippet doesn't compile [message #330391] Mon, 28 July 2008 10:00 Go to next message
David  Pérez is currently offline David PérezFriend
Even though I'm using Eclipse 3.4, the following snippet doesn't compile:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet044NoColumnTableViewerKeyboardEditing.java? view=markup
This is the error I get:
FocusBorderCellHighlighter cannot be resolved to a type
line 148
I've search unluckily for this class in the documentation and the Eclipse
source code.
Re: JFace snippet doesn't compile [message #330395 is a reply to message #330391] Mon, 28 July 2008 10:07 Go to previous messageGo to next message
By replacing FocusBorderCellHighlighter with
FocusCellOwnerDrawHighlighter, I can get it to compile. :-)
David Perez wrote:
> line 148
> source code.
Re: JFace snippet doesn't compile [message #330414 is a reply to message #330391] Mon, 28 July 2008 12:36 Go to previous messageGo to next message
David Perez wrote:
> line 148
> Eclipse source code.
It's possible that this snippet has already been updated to use the code
from the 3.5 development stream, and that FocusBorderCellHighlighter is
a new class in 3.5.
If you checked out the snippets project from CVS, I'd recommend to
replace the project with a tag that marked the release of 3.4
Hope this helps,
Eric
Re: JFace snippet doesn't compile [message #330419 is a reply to message #330414] Mon, 28 July 2008 12:47 Go to previous messageGo to next message
Hi Eric,
I haven't taken directly from CVS, but from the wiki:
http://wiki.eclipse.org/index.php/JFaceSnippets#Snippet021Ce llEditorsOnDoubleClick
> a new class in 3.5.
Re: JFace snippet doesn't compile [message #330581 is a reply to message #330414] Mon, 04 August 2008 12:26 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
No the class he wants is also part of the snippet package! It's much
better to checkout the code directly from CVS!
Tom
Eric Rizzo schrieb:
> David Perez wrote:
>> line 148
> a new class in 3.5.
> Hope this helps,
> Eric
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Previous Topic:Why ColumnViewerEditorActivationListener isn't called
Next Topic:Links in quick fix hovers
Current Time: Thu Dec 26 14:49:49 GMT 2024
Powered by FUDForum. Page generated in 0.15172 seconds
