Home » Eclipse Projects » Eclipse Platform » Ctrl+S different behaviour in Eclipse 3.3 and 3.4
Ctrl+S different behaviour in Eclipse 3.3 and 3.4 [message #330360] Sat, 26 July 2008 07:46 Go to next message
I'm developing a multi page editor, similar to the Eclipse Manifest/PlugIn
editor.
Thus my editor class extends org.eclipse.ui.forms.editor.FormEditor.
And it implements the method doSave(IProgressMonitor progressMonitor).
One of the tabs contains a "source editor", which is a subclass of
org.eclipse.ui.editors.text.TextEditor.
This has got a implementation of doSave(IProgressMonitor progressMonitor)
by default (from org.eclipse.ui.texteditor.AbstractTextEditor).
My intention is, that my doSave(IProgressMonitor progressMonitor) method
is called, whenever the user performs a save action.
Whether by clicking the save icon or pressing Ctrl+S.
It works fine in Eclipse 3.3.
But in 3.4 there is a problem, if the source tab is currently active and a
save action is performed.
Clicking the icon calls my doSave() method, but pressing Crtl+S calls the
doSave() in AbstractTextEditor.
But I want that my doSave() method is called every time.
Why is it working in 3.3 but not in 3.4?
Was there a API change or is it a bug?
It seems like the Key handling is different.
In 3.3 it perform the save action in the top level editor class (
multipage editor ).
But in 3.4 it perform the save action in the text editor, which is part of
the multi page editor.
Re: Ctrl+S different behaviour in Eclipse 3.3 and 3.4 [message #330427 is a reply to message #330360] Mon, 28 July 2008 12:44 Go to previous messageGo to next message
Please open a bug at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=UI
While it should be calling your doSave(*) method on your MPEP,
TextEditor might be an ISaveableSource. Can you reproduce the problem
with a basic MPEP with an embedded TextEditor?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Ctrl+S different behaviour in Eclipse 3.3 and 3.4 [message #330505 is a reply to message #330427] Wed, 30 July 2008 11:24 Go to previous message
Here is the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242582
See the attachment to reproduce it.
It's a basic MPEP with a GUI page and an embedded text editor page.
> PW
Previous Topic:[RSA][Plugin Dev][Modeling] Properties view
Next Topic:Re: Cut/copy/paste at the widget level
Current Time: Sat Oct 18 13:53:40 EDT 2025
Powered by FUDForum. Page generated in 0.03945 seconds
