Home » Eclipse Projects » Eclipse Platform » Building Eclipse 3.4 From Sources Fails
Building Eclipse 3.4 From Sources Fails [message #330344] Fri, 25 July 2008 16:30 Go to next message
Originally posted by: mailtocurious.rediffmail.com
Followed instructions.html inside eclipse-sourceBuild-srcIncluded-3.4.zip
Using:
apache-ant-1.7.1
Windows XP Professional SP2
AMD Sempron 2500+
Environment variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;D:\e\software\apache_ant \apache-ant-1.7.1\bin;C:\Program
Files\Java\jdk1.6.0_07\bin;D:\e\software\info_unzip;D:\e\sof tware\info_zip
D:\ec>echo %JAVA_HOME%
C:\Program Files\Java\jdk1.6.0_07
D:\ec>echo %ANT_HOME%
D:\e\software\apache_ant\apache-ant-1.7.1
D:\ec>echo %CLASS_PATH%
%CLASS_PATH%
Above lines show that CLASS_PATH has not been defined as suggested in:
http://ant.apache.org/manual/install.html#installing
Changed build.properties file to contain:
J2SE-1.4="C:\\Program Files\\Java\\j2sdk1.4.2_17\\jre\\lib"
J2SE-1.5="C:\\Program Files\\Java\\jdk1.5.0_16\\jre\\lib"
JavaSE-1.6="C:\\Program Files\\Java\\jdk1.6.0_07\\jre\\lib"
To build Eclipse:
D:\ec>build -os win32 -ws win32 -arch x86 > buildlog.txt
The result in buildlog.txt:
[echo] TARGET: compiler
[echo] UPDATE ecj.jar
BUILD SUCCESSFUL
Total time: 12 seconds
[echo] TARGET: compiler2
[echo] compilerArg -enableJavadoc -nowarn -encoding ISO-8859-1
[echo] build compiler org.eclipse.jdt.core.JDTCompilerAdapter
BUILD SUCCESSFUL
Total time: 11 seconds
[echo] Deleting jars to recompile...
[echo] Compiling...
[javac] incorrect classpath:
D:\ec\plugins\org.eclipse.equinox.launcher\"C
[javac] incorrect classpath: D:\Program
Files\Java\j2sdk1.4.2_17\jre\lib"
[javac] ----------
[javac] 1. ERROR in
D:\ec\plugins\org.eclipse.equinox.launcher\src\org\eclipse\c ore\launcher\Main.java
(at line 1)
[javac]
[javac] ^
[javac] The type java.lang.Object cannot be resolved. It is indirectly
referenced from required .class files
[javac] ----------
[javac] 2. ERROR in
(at line 23)
[javac] public class Main {
[javac] ^^^^
[javac] Implicit super constructor Object() is undefined for default
constructor. Must define an explicit constructor
[javac] ----------
[javac] 3. ERROR in
(at line 29)
[javac] public static void main(String[] args) {
[javac] ^^^^^^
[javac] String cannot be resolved to a type
[javac] ----------
.... and hundreds of such errors.
The result on console:
BUILD FAILED
D:\ec\build.xml:68: The following error occurred while executing this line:
D:\ec\build.xml:8: The following error occurred while executing this line:
D:\ec\features\org.eclipse.sdk\build.xml:39: The following error occurred
D:\ec\features\org.eclipse.sdk\build.xml:17: The following error occurred
D:\ec\features\org.eclipse.platform\build.xml:341: The following error
D:\ec\features\org.eclipse.platform\build.xml:327: The following error
D:\ec\features\org.eclipse.help\build.xml:95: The following error occurred
D:\ec\features\org.eclipse.help\build.xml:82: The following error occurred
D:\ec\features\org.eclipse.rcp\build.xml:314: The following error occurred
D:\ec\features\org.eclipse.rcp\build.xml:15: The following error occurred
D:\ec\plugins\org.eclipse.equinox.launcher\build.xml:137: The following
D:\ec\plugins\org.eclipse.equinox.launcher\build.xml:95: Compile failed;
see the compiler error output for details.
Total time: 25 seconds
Tried with changed build.properties file:
J2SE-1.4=C:\Program Files\Java\j2sdk1.4.2_17\jre\lib
J2SE-1.5=C:\Program Files\Java\jdk1.5.0_16\jre\lib
JavaSE-1.6=C:\Program Files\Java\jdk1.6.0_07\jre\lib
Same result as above build fails so again tried with changed
JavaSE-1.6='C:\Program Files\Java\jdk1.6.0_07\jre\lib'
Same result as above build fails..
- Have tried to edit build.bat and passed -debug to Ant but could not
figure out much from it.
- Have tried to build with org.eclipse.equinox.launcher\build.xml using
Ant and seems to build successfully.
Is it possible to somehow figure out the dependencies among all the
plugins so that as hinted in instructions.html inside
eclipse-sourceBuild-srcIncluded-3.4.zip one can build all the plugins
separately and get an eclipse build?
- Is it that eclipse uses its own complier to build all
modules/plugins except ecj.jar?
A related post but seems like nobody has responded.
http://dev.eclipse.org/newslists/news.eclipse.platform/msg58 967.html
Thank you very much for your patience.
Cheers.
Re: Building Eclipse 3.4 From Sources Fails [message #330569 is a reply to message #330344] Sun, 03 August 2008 20:59 Go to previous messageGo to next message
Originally posted by: chenal.naritech.cn
exquisitus 写道:
> Using: eclipse-sourceBuild-srcIncluded-3.4.zip
> apache-ant-1.7.1
> AMD Sempron 2500+
> %CLASS_PATH%
> To build Eclipse:
> BUILD SUCCESSFUL
> BUILD SUCCESSFUL
> [echo] Compiling...
> [javac] ----------
> [javac] 1. ERROR in
> (at line 1)
> [javac]
> [javac] ^
> indirectly referenced from required .class files
> [javac] ----------
> [javac] 2. ERROR in
> (at line 23)
> [javac] ^^^^
> [javac] ----------
> [javac] 3. ERROR in
> (at line 29)
> [javac] ^^^^^^
> [javac] ----------
> BUILD FAILED
> - Is it that eclipse uses its own complier to build all modules/plugins
> except ecj.jar?
> Cheers.
I also have this question. I build eclipse 3.4 on windows xp and solaris
10. Both failed with the above mentioned errors.
Who has successfully built eclipse 3.4?
Allen
Re: Building Eclipse 3.4 From Sources Fails [message #331011 is a reply to message #330569] Thu, 21 August 2008 04:36 Go to previous messageGo to next message
Originally posted by: ningliangnl1.gmail.com
do some modification to build.properties as follows:
J2SE-1.4=[JDK1.4-HOME]\\jre\\lib\\rt.jar;[JDK1.4-HOME]\\jre\ \lib\\jsse.jar;[JDK1.4-HOME]\\jre\\lib\\jce.jar;
J2SE-1.5=[JDK1.5-HOME]\\jre\\lib\\rt.jar;[JDK1.4-HOME]\\jre\ \lib\\jsse.jar;[JDK1.4-HOME]\\jre\\lib\\jce.jar;
JavaSE-1.6=[JDK1.6-HOME]\\jre\\lib\\rt.jar;[JDK1.4-HOME]\\jr e\\lib\\jsse.jar;[JDK1.4-HOME]\\jre\\lib\\jce.jar;
maybe, it will works~
good luck~
Re: Building Eclipse 3.4 From Sources Fails [message #331012 is a reply to message #331011] Thu, 21 August 2008 04:39 Go to previous message
do some modifications to build.properties as follows:
J2SE-1.5=[JDK1.5-HOME]\\jre\\lib\\rt.jar;[JDK1.5-HOME]\\jre\ \lib\\jsse.jar;[JDK1.5-HOME]\\jre\\lib\\jce.jar;
JavaSE-1.6=[JDK1.6-HOME]\\jre\\lib\\rt.jar;[JDK1.6-HOME]\\jr e\\lib\\jsse.jar;[JDK1.6-HOME]\\jre\\lib\\jce.jar;
maybe, it will work~
good luck~
Previous Topic:How do I know if Save button is pressed?
Next Topic:Plugin was not loaded
Current Time: Tue Sep 16 22:07:12 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
