| Re: Cut/copy/paste at the widget level [message #330507 is a reply to message #330290] |
Wed, 30 July 2008 12:09  |
Originally posted by: davidhuebel.example.net
Paul Webster wrote:
> Within eclipse you can use the IFocusService to register a specific
> control to the system (using an id, usually).
> Then you can activate a handler for that Control using the appropriate
> activeWhen clause (and org.eclipse.ui.handlers) or by using a Expression
> and IHandlerService#activateHandler(*).
> See ISources and http://wiki.eclipse.org/Command_Core_Expressions for a
> discussion of variables available, and IFocusService javadoc for a
> description of its use.
> PW
Thanks! This is exactly what I needed.
-David
FUDForum. Page generated in 0.04957 seconds
