Home » Eclipse Projects » Eclipse Platform » ant taskdef and classpath problem
ant taskdef and classpath problem [message #33439] Thu, 15 May 2003 12:18 Go to next message
Originally posted by: celine.mortelette.atosorigin.com
Hello !
I have a problem with ant taskdef in Eclipse 2.1.
I have an Eclipse project, which contains an ant build file.
When I add a new external tool for my project (in properties > External
tools Builders > New > Ant Build), and when I want to access to the
"Targets" tab, I have this error :
build.xml:taskdef class
org.apache.axis.tools.ant.wsdl.Wsdl2javaAntTask cannot be found
and yet, I had put the library axis-ant.jar in my project classpath.
So I put it in the ant runtime classpath in "Window > Preferences > Ant >
Runtime > Classpath", but it does not work better !!
How can I do to avoid this error ??
C
Re: ant taskdef and classpath problem [message #33754 is a reply to message #33439] Thu, 15 May 2003 14:09 Go to previous messageGo to next message
Celine,
Where did you add the library axis-ant.jar to the Ant runtime classpath?
2.1 has a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=36574 where
additional classpath entries are not considered correctly.
The workaround is to add the JAR(s) directly to the Runtime classpath
instead of in the additional classpath entries.
HTH
Darins
"C
Re: ant taskdef and classpath problem [message #35387 is a reply to message #33754] Fri, 16 May 2003 07:51 Go to previous messageGo to next message
I have put my classpath in the "Runtim classpath" list !!
But it does not work ....
And I have put it on the top of the list !
Is it a bug ?
"Darin Swanson" <Darin_Swanson@us.ibm.com> a
Re: ant taskdef and classpath problem [message #37776 is a reply to message #35387] Mon, 19 May 2003 10:05 Go to previous message
It works now.
The error message indicated a class not found, but the problem was another
class.
Thank you for your help
C
Previous Topic:A date for Eclipse 2.1.1
Next Topic:Loading default Editors
Current Time: Thu Mar 13 13:45:52 EDT 2025
Powered by FUDForum. Page generated in 0.02516 seconds
