Home » Eclipse Projects » Eclipse Platform » Plugin.xml split editor is not synchronous
Plugin.xml split editor is not synchronous [message #330212] Mon, 21 July 2008 09:49 Go to next message
I accept the fact that there is no split editor in Eclipse. We can use "New
editor" option instead when right-clicking on the header of an editor. And I
also accept that I can not disable it or make it invisible without writing a
whole presentation of my own.
But the behaviour of "New Editor" option is not consistent. If you use Java
Editor or Text Editor, it works perfectly. It is synchronous. When you write
something on any one of the editors, it is immediately written in the other
one. And when you change something and close one of the editors it does not
pop a "Save Resource Co
Re: Plugin.xml split editor is not synchronous [message #330224 is a reply to message #330212] Mon, 21 July 2008 13:15 Go to previous messageGo to next message
Kerem wrote:
> When coding a new type of Editor in a plugin or in an RCP application, is
> New Editor option's behavior settable somewhere?
> Is there a way to synchronize all the widgets (texts,combos and even the
> tables) without writing code for all widget instances in my form in a plugin
> or in an RCP application?
I think you'd want to do something like that by having the two editors
share a model. Then, using the Data Binding framework would make it
pretty easy to have multiple views on that model. Your model will have
to fire change notification events (like a JavaBean or an EMF model) for
Data Binding to work that way.
Hope this helps,
Eric
Re: Plugin.xml split editor is not synchronous [message #330233 is a reply to message #330224] Tue, 22 July 2008 07:36 Go to previous message
Thanks Eric.
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:g62g4e$9no$1@build.eclipse.org...
>> plugin or in an RCP application?
> share a model. Then, using the Data Binding framework would make it pretty
> easy to have multiple views on that model. Your model will have to fire
> change notification events (like a JavaBean or an EMF model) for Data
> Hope this helps,
> Eric
Previous Topic:not to close parent dialog on cancel of child wizard
Next Topic:IContributionItems Access details
Current Time: Sun Apr 27 00:50:06 EDT 2025
Powered by FUDForum. Page generated in 0.02612 seconds
