Re: Plugin.xml split editor is not synchronous [message #330224 is a reply to message #330212] |
Mon, 21 July 2008 17:15 |
Kerem wrote:
> When coding a new type of Editor in a plugin or in an RCP application, is
> New Editor option's behavior settable somewhere?
> Is there a way to synchronize all the widgets (texts,combos and even the
> tables) without writing code for all widget instances in my form in a plugin
> or in an RCP application?
I think you'd want to do something like that by having the two editors
share a model. Then, using the Data Binding framework would make it
pretty easy to have multiple views on that model. Your model will have
to fire change notification events (like a JavaBean or an EMF model) for
Data Binding to work that way.
Hope this helps,
Eric
FUDForum. Page generated in 0.02594 seconds
