Re: problemreporter bug in 0.95.1 released version [message #33494 is a reply to message #33416] |
Mon, 20 October 2008 08:16 |
Alex Panchenko Messages: 342 Registered: July 2009 |
--------------050608010501080806080704
Hi Sheela,
At the moment you can use a workaround similar to the attached.
We will make the proper fix in CVS and it will be released as part of
the 0.95.2 bugfix release.
Alex
Sheela wrote:
> We are releasing our IDE with DLTK 0.95.1 released version.But there
> seems to be a bug in the problem reporter.
> The issue is suppose i open a script file, make a small change so as to
> produce a syntax error, the errors are reported in problems view.
> So far so good; now close the script without saving, the problems view
> is not cleared.
> When i reopen the file, it opens the saved file which doesnot have any
> syntax errors. But my problems view still shows errors of the unsaved
> version.
> I tried to debug and found that getProblemReporter() in
> AbstractSourceElementParser is null, for first parse on the script file,
> which is why it fails.
> It has been solved in the latest integration build but we are about to
> release our product with 0.95.1 dltk released version. Can we have some
> fix for this version.
> Please do the needful.
> Thanks and regards,
> sheela.
name="reparse-dispose-unsaved-changes.patch"
Content-Disposition: inline;
filename="reparse-dispose-unsaved-changes.patch"
### Eclipse Workspace Patch 1.0
#P org.eclipse.dltk.ruby.ui
Index: src/org/eclipse/dltk/ruby/internal/ui/editor/RubyEditor.java
RCS file: /cvsroot/technology/org.eclipse.dltk/ruby/plugins/org.eclips e.dltk.ruby.ui/src/org/eclipse/dltk/ruby/internal/ui/editor/ RubyEditor.java,v
retrieving revision 1.19.4.1
diff -u -r1.19.4.1 RubyEditor.java
--- src/org/eclipse/dltk/ruby/internal/ui/editor/RubyEditor.java 20 Oct 2008 07:45:04 -0000 1.19.4.1
+++ src/org/eclipse/dltk/ruby/internal/ui/editor/RubyEditor.java 20 Oct 2008 08:10:43 -0000
@@ -9,10 +9,17 @@
package org.eclipse.dltk.ruby.internal.ui.editor;
+import org.eclipse.core.resources.IFile;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.ListenerList;
+import org.eclipse.dltk.compiler.problem.IProblemFactory;
+import org.eclipse.dltk.core.DLTKLanguageManager;
import org.eclipse.dltk.core.IDLTKLanguageToolkit;
import org.eclipse.dltk.core.IModelElement;
+import org.eclipse.dltk.core.ISourceModule;
+import org.eclipse.dltk.core.ModelException;
+import org.eclipse.dltk.core.SourceParserUtil;
+import org.eclipse.dltk.internal.core.ModelManager;
import org.eclipse.dltk.internal.ui.actions.FoldingActionGroup;
import org.eclipse.dltk.internal.ui.editor.DLTKEditorMessages;
import org.eclipse.dltk.internal.ui.editor.ScriptEditor;
@@ -23,6 +30,7 @@
import org.eclipse.dltk.ruby.internal.ui.text.IRubyPartitions;
import org.eclipse.dltk.ruby.internal.ui.text.RubyPairMatcher;
import org.eclipse.dltk.ruby.internal.ui.text.folding.RubyFoldingSt ructureProvider;
+import org.eclipse.dltk.ui.DLTKUIPlugin;
import org.eclipse.dltk.ui.actions.IScriptEditorActionDefinitionIds ;
import org.eclipse.dltk.ui.text.ScriptTextTools;
import org.eclipse.dltk.ui.text.folding.IFoldingStructureProvider;
@@ -195,6 +203,27 @@
if (sourceViewer instanceof ITextViewerExtension)
((ITextViewerExtension) sourceViewer)
.removeVerifyKeyListener(fBracketInserter);
+ if (isDirty()) {
+ final IModelElement modelElement = getInputModelElement();
+ if (modelElement != null) {
+ ISourceModule module = (ISourceModule) modelElement
+ .getAncestor(IModelElement.SOURCE_MODULE);
+ ModelManager.getModelManager().getSourceModuleInfoCache()
+ .remove(module);
+ IFile resource = (IFile) module.getResource();
+ try {
+ module.getBuffer().setContents(
+ org.eclipse.dltk.internal.core.util.Util
+ .getResourceContentsAsCharArray(resource));
+ } catch (ModelException e) {
+ DLTKUIPlugin.log(e);
+ IProblemFactory factory = DLTKLanguageManager
+ .getProblemFactory(getLanguageToolkit().getNatureId());
+ SourceParserUtil.getModuleDeclaration(module, factory
+ .createReporter(resource));
super.dispose();
--------------050608010501080806080704--
Re: problemreporter bug in 0.95.1 released version [message #33527 is a reply to message #33494] |
Mon, 20 October 2008 08:49 |
Sorry, probably it is not clear from the patch: this code should be
placed in the dispose() method of your editor extending ScriptEditor.
Alex Panchenko wrote:
> Hi Sheela,
> Alex
> Sheela wrote:
>> to produce a syntax error, the errors are reported in problems view.
>> is not cleared.
>> version.
>> file, which is why it fails.
>> some fix for this version.
>> Thanks and regards,
>> sheela.
FUDForum. Page generated in 0.02952 seconds
