Home » Eclipse Projects » Eclipse Platform » Adding a template to a custom extension point
Adding a template to a custom extension point [message #330147] Thu, 17 July 2008 01:43 Go to next message
Yigal Spinner is currently offline Yigal SpinnerFriend
I'm new the PDE and could not find how to add a template to a custom
extension point.
I found documentation how to create an extension point and documentation
how to create a wizard for templates in a new project.
I want to create a wizard that will create the target classes for the
extension point.
Can you direct me to some documentation that will help me?
Yigal
Re: Adding a template to a custom extension point [message #330222 is a reply to message #330147] Mon, 21 July 2008 16:50 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
> extension point.
> extension point.
The document at
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.pde.doc.user/guide/tools/project_wizards/plugin_templates. htm
refers to the org.eclipse.pde.ui.pluginContent extension point description.
There are examples that the eclipse SDK provides at
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.pde.ui. templates/
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Property Tester threading question
Next Topic:P2 and unresolved dependencies
Current Time: Sat Dec 21 14:31:52 GMT 2024
Powered by FUDForum. Page generated in 0.05008 seconds
