Modifying plugin.xml file programmatically [message #330137] |
Wed, 16 July 2008 14:25 |
Originally posted by: malloovidio.bluewin.ch
Hi all,
I have a project builder which, among other things, should modify
some parts of the plugin.xml file. More concretely, I want to automatically
add an additional enablement-condition to actions defined in the plugin.xml
file. Therefore, I wanted to ask whether there is some API to read in
specific extensions (the actions in the actionSet) and modify part of it
(the enablement)?
Thanks in advance for any help.
Ovidio
Re: Modifying plugin.xml file programmatically [message #330226 is a reply to message #330137] |
Mon, 21 July 2008 19:14 |
Originally posted by: zx.code9.com
Ovidio Mallo wrote:
> Hi all,
> (the enablement)?
There's no public API to do this... here is a bug you may be interested in:
216037: [API] Way to modify MANIFEST files
https://bugs.eclipse.org/bugs/show_bug.cgi?id=216037
~ Chris
Re: Modifying plugin.xml file programmatically [message #330272 is a reply to message #330226] |
Thu, 24 July 2008 07:48 |
Paul & Chris,
thanks a lot for the pointers. I have ended up using the IPluginElement
interface to get it running. As Chris noted, it needs internal API to
be used but for now I can live with that.
Thanks again for the help!
Ovidio
Chris Aniszczyk wrote:
> Ovidio Mallo wrote:
>> Hi all,
>> automatically
>> plugin.xml
>> (the enablement)?
> Cheers,
> ~ Chris
FUDForum. Page generated in 0.03272 seconds
