Home » Eclipse Projects » Eclipse Platform » Handling passwords in CVS EFS
Handling passwords in CVS EFS [message #330118] Tue, 15 July 2008 13:19 Go to next message
Originally posted by: owong.benchmarkconsulting.com
I'm not sure if this is the right newsgroup, but I couldn't find any
newsgroups with the keywords "team" or "cvs" in them.
From what I understand from http://wiki.eclipse.org/EFS#CVS, the CVS
plugin has an EFS implementation which reads from CVS servers. I was
wondering how the implementation deals with the issue of passwords. Is the
password embedded in the URI? If so, is that secure? If not, how does can
an IFileStore ensure that it has the password it needs to return an
appropriate InputStream? Does it display a file prompt to the user? If so,
does this happen at the EFS layer, or at some higher layer before the EFS
is involved? If not, how does it know what password to use?
Thanks for any help and clarifications you can provide.
Re: Handling passwords in CVS EFS [message #330140 is a reply to message #330118] Wed, 16 July 2008 13:25 Go to previous message
Oliver,
The CVS/UI plug-in registers an authenticator callback with the CVS/Core
plug-in so that, if a password is required, the user gets prompted when
a connection is attempted.
Michael
> the password embedded in the URI? If so, is that secure? If not, how
> does can an IFileStore ensure that it has the password it needs to
> return an appropriate InputStream? Does it display a file prompt to the
> user? If so, does this happen at the EFS layer, or at some higher layer
> before the EFS is involved? If not, how does it know what password to use?
Previous Topic:Editing workset bug - Ganymede (Eclipse IDE for Java EE Developers)
Next Topic:Hyperlink as tableitem in jface/swt table
Current Time: Sat Mar 15 00:54:17 EDT 2025
Powered by FUDForum. Page generated in 0.03997 seconds
