| disable rename action for specific navigator content [message #329958] |
Fri, 11 July 2008 09:12  |
Originally posted by: klammer.utanet.at
I searched for a solution to following problem for some hours now:
I want to disable the 'default' rename action for a specific resource
(identified by file extension). Both 'F2' button and 'context menue
entry' should be disabled.
What I've done so far:
1.) introduced own handler for commands
'org.eclipse.ltk.ui.refactoring.commands.renameResource' and
'org.eclipse.ui.edit.rename' which does nothing when the commands are
executed. This works except the action is still displayed as
'executable' which I do not know how to solve.
2.) So I tried to find a solution to get rid of the menu action entry
completely. But so far I had no luck when trying to overwrite the
org.eclipse.ui.navigator.resources.actions.RefactorActionPro vider for
the specific navigatorContent
Any hints are welcome!
Claus Klammer
using Eclipse 3.4.0 I20080617-2000
| Re: disable rename action for specific navigator content [message #330088 is a reply to message #330052] |
Mon, 14 July 2008 11:28   |
If you are doing an RCP application, give your viewer a different Id,
and make your own viewerContentBinding and navigatorContentExtension
extension points. You can copy much of them from the ones defined in
org.eclipse.ui.resources.
I don't think you can really modify the definition for the
ProjectExplorer instance in this way, as I'm not sure that the excludes
mechanism will work across extension point declarations (one of the
extensions is defined in your plugin, the other in the
org.eclipse.ui.navigator.resources plugin). This might be an
interesting enhancement request.
Francis
Claus Klammer wrote:
> You're right I'm using the Project Explorer and want to adapt its menu
> for an RCP application.
> Despite your hints I was not able to remove the Rename-Action from the
> context menu. As a first step I want to remove the
> RefactorActionProvider completely - to see that thing can be configured
> like expected. But unfortunately this did not work either (see below).
> org.eclipse.ui.navigator.resources plugin in declares content and action
> bindings for the Project Explorer:
> <viewerContentBinding
> viewerId="org.eclipse.ui.navigator.ProjectExplorer">
> <includes>
> <contentExtension
> pattern="org.eclipse.ui.navigator.resourceContent" />
> <contentExtension
> pattern="org.eclipse.ui.navigator.resources.filters.*"/>
> <contentExtension
> pattern="org.eclipse.ui.navigator.resources.linkHelper"/>
> <contentExtension
> pattern="org.eclipse.ui.navigator.resources.workingSets"/>
> </includes>
> </viewerContentBinding>
> <viewerActionBinding
> <includes>
> <actionExtension
> pattern="org.eclipse.ui.navigator.resources.*" />
> </includes>
> </viewerActionBinding>
> In turn the viewerContent org.eclipse.ui.navigator.resourceContent
> specifies the 'RefactorActionProvider' internally which I want to get
> rid of.
> <actionProvider
> class=" org.eclipse.ui.internal.navigator.resources.actions.Refactor ActionProvider "
> id="org.eclipse.ui.navigator.resources.actions.RefactorActions "/>
> So I tried to exclude this content by redeclare it in my own plugin.
> <extension
> point="org.eclipse.ui.navigator.viewer">
> <excludes>
> <contentExtension
> </excludes>
> </extension>
> But this does not work, the refactor context menue entries are still
> there. What I'm doing wrong? How can I control the merge of content
> declarations (is it now included or excluded)?
> Any tips how I can find out/debug this are very appreciated!
> Thanks in advance,
> Claus Klammer
> Francis Upton (News) schrieb:
>> You are using the Project Explorer (Common Navigator)?
>> If so, then you will need to split the RefactorActionProvider into
>> two classes, one for rename and one for move.
>> Then make content extensions that define the enablement of each of
>> these using the org.eclipse.ui.navigatorContent extention point.
>> Finally in the org.eclipse.ui.navigatorViewer extension point bind to
>> the new content extensions and remove the binding to the one that
>> comes with eclipse. (You may need to remove a wildcard binding and
>> specify all of the content extensions you want directly).
>> I assume this is for an RCP application and not a plugin. If it's a
>> plugin things are more complicated because you don't control the use
>> of the extension points that defined the Project Explorer and there
>> are other types of resources where you will not want to interfere. I
>> would have to think about solving the problem in that case.
>>> Regards,
>>> Claus Klammer
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
| Re: disable rename action for specific navigator content [message #330102 is a reply to message #330088] |
Tue, 15 July 2008 02:44   |
Francis, thanks for your help!
Because of your hints I was able to find a feasible solution for my
problem finally.
I defined my own navigatorContent which overrides the default navigator
resource content and uses a custom ActionProvider which overrides the
standard navigator RefactorActions and provides only the 'Move' action.
<override
suppressedExtensionId="org.eclipse.ui.navigator.resourceContent ">
</override>
<actionProvider
class="com.xx.xx.xx.ui.actions.RefactorActionProvider"
id="com.xx.xx.xx.actions.RefactorActions"
overrides="org.eclipse.ui.navigator.resources.actions.RefactorActions "
priority="highest">
<enablement>
<test
property="org.eclipse.core.resources.name"
value="*.whatever">
</test>
</enablement>
</actionProvider>
If the extension name of the resource matches the defined value the user
defined action provider is used instead of the default one -> rename is
not available anymore.
Although I solve my problem, I would appreciate a 'problem - solution'
page (wiki?) for such - more or less - tricky declaration challenges.
Even the declaration point description is good in my point of view a
more problem solution oriented help would be very useful. Escpecially
since the required declarations are often spread around many extension
points. Perhaps a link to an existing configuration that issues the same
problem might help.
Claus
> Francis
>> the context menu. As a first step I want to remove the
>> configured like expected. But unfortunately this did not work either
>> (see below).
>> action bindings for the Project Explorer:
>> <includes>
>> <contentExtension
>> <contentExtension
>> <contentExtension
>> <contentExtension
>> </includes>
>> <includes>
>> <actionExtension
>> </includes>
>> rid of.
>> <actionProvider
>> <extension
>> <excludes>
>> <contentExtension
>> </excludes>
>> </extension>
>> Thanks in advance,
>> Claus Klammer
>>>> resource (identified by file extension). Both 'F2' button and
>>>> 'context menue entry' should be disabled.
>>>> are executed. This works except the action is still displayed as
>>>> entry completely. But so far I had no luck when trying to overwrite
>>>> the
>>>> for the specific navigatorContent
>>>> Regards,
>>>> Claus Klammer
FUDForum. Page generated in 0.25875 seconds
