Re: How to set dynamic text in splash screen [message #329953 is a reply to message #329952] |
Fri, 11 July 2008 10:35 |
On Fri, 11 Jul 2008 09:39:54 +0000 (UTC), haribabu2006@gmail.com
(HariBabu) wrote:
>Hi,
>I needs to put a text in the splash screen which will changes dynamically
>how can i achieve this.
>Example: when i have started the eclipse it displays the splash.bmp file,
>likewise i have my own bmp file and wanted to display a dynamic text into
>this. please help me.
>Thanks
>-Hari
I tested this in Eclipse 3.4 but i think it is available in older
versions:
Open the "New Project..." wizard
Select the "Plug-in Project"
Set "Project name" and leave the other options alone
Advance to the "Templates" page
Select "Custom plug-in wizard", choose "Next"
Deselect all Templates and select the "Splash Handler" Template
Choose the kind of Splash screen you want on the next page
Finish
The generated plug-in might already fullfil your requirements.
Otherwise just modify it.
Achim
Achim Lörke
Eclipse-Stammtisch in the Braunschweig, Germany area:
http://www.bredex.de/de/news/events.html
Achim Lörke
FUDForum. Page generated in 0.03742 seconds
