NullPointerException from EquinoxFwConfigFileParser.makeAbsolute() [message #329940] |
Thu, 10 July 2008 22:19 |
Originally posted by: ofrijole.hotmail.com
I'm working on building some plugins which my company has working with
Eclipse 3.2 with 3.4. I'm seeing the following error and I can't figure
out where it is coming from. I saw something like this in a web search
that found the following link:
http://download.eclipse.org/eclipse/downloads/drops/I2008070 2-0939/testresults/win32.win32.x86/org.eclipse.equinox.p2.te sts.automatedtests.txt
I don't know if this is useful or not. Anyway, here's what I see:
!SESSION 2008-07-10 14:34:57.126
eclipse.buildId=I20080617-2000
java.version=1.5.0_13
Framework arguments: -application org.eclipse.ant.core.antRunner
-buildfile C:\Viewstore\build.xml Build-All-Plugins
Command-line arguments: -application org.eclipse.ant.core.antRunner
!ENTRY org.eclipse.equinox.p2.garbagecollector 4 2 2008-07-10 14:35:12.750
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.equinox.p2.garbagecollector".
!STACK 0
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser.makeAbsolute(EquinoxFwConfigFileParser.jav a:398)
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser.readFwConfig(EquinoxFwConfigFileParser.jav a:271)
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxM anipulatorImpl.loadWithoutFwPersistentData(EquinoxManipulato rImpl.java:368)
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxM anipulatorImpl.initializeRuntime(EquinoxManipulatorImpl.java :277)
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxM anipulatorImpl. <init>(EquinoxManipulatorImpl.java:126)
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wAdminImpl.getRunningManipulator(EquinoxFwAdminImpl.java:100 )
org.eclipse.equinox.internal.p2.touchpoint.eclipse.WhatIsRun ning.getFrameworkManipulator(WhatIsRunning.java:21)
org.eclipse.equinox.internal.p2.touchpoint.eclipse.WhatIsRun ning.getBundlesBeingRun(WhatIsRunning.java:15)
org.eclipse.equinox.internal.p2.touchpoint.eclipse.MarkSetPr ovider.addRunningBundles(MarkSetProvider.java:110)
org.eclipse.equinox.internal.p2.touchpoint.eclipse.MarkSetPr ovider.getMarkSets(MarkSetProvider.java:47)
org.eclipse.equinox.internal.p2.garbagecollector.GarbageColl ector$ParameterizedSafeRunnable.run(GarbageCollector.java:12 5)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.equinox.internal.p2.garbagecollector.GarbageColl ector.contributeMarkSets(GarbageCollector.java:135)
org.eclipse.equinox.internal.p2.garbagecollector.GarbageColl ector.traverseMainProfile(GarbageCollector.java:67)
org.eclipse.equinox.internal.p2.garbagecollector.GarbageColl ector.runGC(GarbageCollector.java:43)
org.eclipse.equinox.internal.p2.garbagecollector.GCActivator $1.notify(GCActivator.java:74)
org.eclipse.equinox.internal.p2.core.ProvisioningEventBus.di spatchEvent(ProvisioningEventBus.java:86)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.equinox.internal.p2.core.ProvisioningEventBus.pu blishEvent(ProvisioningEventBus.java:71)
org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:61)
org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSy nchronizer.executeOperands(ProfileSynchronizer.java:358)
org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSy nchronizer.executePlan(ProfileSynchronizer.java:349)
org.eclipse.equinox.internal.p2.reconciler.dropins.ProfileSy nchronizer.synchronize(ProfileSynchronizer.java:99)
org.eclipse.equinox.internal.p2.reconciler.dropins.Activator .synchronize(Activator.java:402)
org.eclipse.equinox.internal.p2.reconciler.dropins.Activator .start(Activator.java:161)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
FUDForum. Page generated in 0.03370 seconds
