Home » Eclipse Projects » Eclipse Platform » Re: ShowInMenu
Re: ShowInMenu [message #329930] Thu, 10 July 2008 14:46 Go to next message
Paul Wells wrote:
> I'm working on a project which uses the JDT to create class diagrams.
> One of the popup actions has stopped working since Ganymede.
> The action uses org.eclipse.ui.internal.ShowInMenu to allow the user to
> navigate to other views such as the History or the Project Explorer
> depending upon the currently selected java element in the class diagram.
> Yes - I know you're not supposed to use the internal packages. Is there
> a way I can invoke this action without accessing an internal package?
> Here's the code:
> MenuManager showInMenuManager = new MenuManager("Show In");
> ShowInMenu showInMenu = new
> ShowInMenu(getDiagram().getDiagramEditor().getSite().getWork benchWindow(),
> "show in");
> showInMenuManager.add(showInMenu);
> popupEvent.getMenuManager().add(showInMenuManager);
> Because the diagram is a selection provider showInMenu always worked
> like magic. Since Ganymede it looks like it has become more choosy about
> which view it is invoked from.
re-routing to eclipse.platform
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: ShowInMenu [message #329931 is a reply to message #329930] Thu, 10 July 2008 15:15 Go to previous message
Paul Webster wrote:
> Paul Wells wrote:
>> Here's the code:
>> "show in");
It was modified in 3.4 to integrate with menu contributions as well as
the other show in sources.
What if you change those 2 lines to:
ShowInMenu showInMenu = new ShowInMenu();
showInMenu.setId("showIn");
showInMenu.initialize(getDiagram().getDiagramEditor().getSit e().getWorkbenchWindow());
which is how it is used in 3.4 in
org.eclipse.ui.actions.ContributionItemFactory.VIEWS_SHOW_IN
Does that help?
PW
Paul Webster
Previous Topic:How to programatically customize perspective
Next Topic:Viewer is busy
Current Time: Sun Nov 02 14:04:34 EST 2025
Powered by FUDForum. Page generated in 0.05326 seconds
