Home » Eclipse Projects » Eclipse Platform » Editing workset bug - Ganymede (Eclipse IDE for Java EE Developers)
Editing workset bug - Ganymede (Eclipse IDE for Java EE Developers) [message #329903] Thu, 10 July 2008 09:39 Go to next message
Vasil E. Kostadinov is currently offline Vasil E. KostadinovFriend
I am using Ganymende version package: "Eclipse IDE for Java EE
Developers". I've encountered a bug while editing a working set. I did not
find anything like this reported either here or in the bugzilla.
So here is the bug:
When editing a working set and adding new project(s) to it once you hit
button "Finish" eclipse leaves only the opened projects (if any) in the
workset you just edited + the newly added once (no matter if they are
opened or not). Same thing happens to all my colleagues too (they use the
same eclipse version and package)
I wonder if this is a bug at all and that is why I am asking here before
posting to bugzilla.
P.S. Sorry for my English it is not my native language.
Re: Editing workset bug - Ganymede (Eclipse IDE for Java EE Developers) [message #329916 is a reply to message #329903] Thu, 10 July 2008 15:06 Go to previous messageGo to next message
Francis Upton IV is currently offline Francis Upton IVFriend
Are you using the "Project Explorer" or the "Package Explorer"? There
are some known problems in this area with the Project Explorer (also
known as the Common Navigator).
Vasil E. Kostadinov wrote:
> not find anything like this reported either here or in the bugzilla. So
> here is the bug: When editing a working set and adding new project(s) to
> it once you hit button "Finish" eclipse leaves only the opened projects
> (if any) in the workset you just edited + the newly added once (no
> matter if they are opened or not). Same thing happens to all my
> colleagues too (they use the same eclipse version and package)
*new* Common Navigator Framework section in:
3.4RC4 Platform Plugin Developer Guide (Programmer's Guide)
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/cnf.htm
http://dev.eclipse.org/blogs/francis
http://wiki.eclipse.org/Common_Navigator_Framework
http://wiki.eclipse.org/Common_Navigator_Framework_Use_Cases
You have brains in your head.
You have feet in your shoes.
- Dr Seuss, Oh the Places You'll Go
Re: Editing workset bug - Ganymede (Eclipse IDE for Java EE Developers) [message #330134 is a reply to message #329916] Wed, 16 July 2008 13:28 Go to previous message
I am using 'Package Explorer'.
Previous Topic:disable rename action for specific navigator content
Next Topic:Handling passwords in CVS EFS
Current Time: Fri Dec 27 03:30:15 GMT 2024
Powered by FUDForum. Page generated in 0.03226 seconds
