Debug: 'process model delta' has encountered a problem [message #329893] |
Wed, 09 July 2008 20:35 |
Originally posted by: bobdobolina.mailinator.com
When debugging an RMI application I get the following error dialog:
Details:
ERROR
No idea what's up here, but seems to have to do with progress ui of
eclipse when debugging. Not sure what component I should report it under.
Any insights?
Ganymede J2EE package.
Checking the log view gives the following detail stack trace (in swt):
From EventLog Details:
eclipse.buildId=I20080617-2000
java.version=1.6.0_05
Framework arguments: -Dide.gc=true
Command-line arguments: -os win32 -ws win32 -arch x86 -data d:\ws34
-Dide.gc=true
Error
Wed Jul 09 13:56:37 MDT 2008
Unhandled event loop exception
org.eclipse.swt.SWTException: Failed to execute runnable
(java.lang.IllegalArgumentException: Index out of bounds)
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:136)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3800)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3425)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Caused by: java.lang.IllegalArgumentException: Index out of bounds
at org.eclipse.swt.SWT.error(SWT.java:3761)
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.widgets.Widget.error(Widget.java:463)
at org.eclipse.swt.widgets.TreeItem.getItem(TreeItem.java:735)
at org.eclipse.jface.viewers.TreeViewer.replace(TreeViewer.java :500)
org.eclipse.debug.internal.ui.viewers.model.TreeModelContent Provider.reveal(TreeModelContentProvider.java:336)
org.eclipse.debug.internal.ui.viewers.model.TreeModelContent Provider.handleReveal(TreeModelContentProvider.java:319)
org.eclipse.debug.internal.ui.viewers.model.ModelContentProv ider.updateNodes(ModelContentProvider.java:882)
org.eclipse.debug.internal.ui.viewers.model.ModelContentProv ider.updateNodes(ModelContentProvider.java:884)
org.eclipse.debug.internal.ui.viewers.model.ModelContentProv ider$9.runInUIThread(ModelContentProvider.java:833)
at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:94)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:133)
... 22 more
Re: Debug: 'process model delta' has encountered a problem [message #330217 is a reply to message #329893] |
Mon, 21 July 2008 16:02 |
Originally posted by: plutchak.uiuc.edu
For what it's worth, I've been seeing the same type of behavior while
debugging. I get the error intermittently when at a breakpoint and I hit
any of the step icons. Also, when in that state, the "variables" window
is blank even when it should contain variables and values.
FUDForum. Page generated in 0.03887 seconds
