Home » Eclipse Projects » Eclipse Platform » Cannot start RCP product exported under Eclipse 3.4
Cannot start RCP product exported under Eclipse 3.4 [message #329859] Tue, 08 July 2008 13:05 Go to next message
Originally posted by: mircea.luchian.matrox.com
--------------000708030006010509040705
I recently upgraded from Eclipse 3.3 to 3.4. My RCP application starts
fine under Eclipse 3.4 if I run it from the "launch Eclipse product"
link in the .product editor.
However, if I export this product and click on the executable, the
application fails to start and the following error occurs: _Unable to
acquire application service. Ensure that the org.eclipse.core.runtime
bundle is resolved abd started (see config.ini)_
and the log displays the following:
!ENTRY org.eclipse.osgi 4 0 2008-07-08 12:50:12.941
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
My config.ini looks as follows and the org.eclipse.core.runtime plugin
is included in the product configuration.
config.ini built with 3.4:
#Product Runtime Configuration File
osgi.splashPath=platform:/base/plugins/com.matrox.fdk.core
eclipse.product=com.matrox.fdk.core.product
osgi.bundles.defaultStartLevel=4
osgi.bundles=org.eclipse.equinox.transforms.hook@4
As a reference, the config.ini file generated by Eclipse 3.3 is located
below, however, when I copied the same parameters in the config.ini of
the RCP app build with Eclipse 3.4, the application failed to start
properly. The splash screen was appearing and disappearing repeatedly as
if the application wanted to start, but terminated before the workbench
could kick in.
config.ini built with 3.3:
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
How can this problem be resolved?
Mircea
Content-Type: multipart/related;
boundary="------------040801070208000606020102"
--------------040801070208000606020102
<html>
<head>
</head>
Hello, <br>
<br>
link in the .product editor. <br>
application fails to start and the following error occurs: <u>Unable
to acquire application service. Ensure that the
org.eclipse.core.runtime bundle is resolved abd started (see config.ini)</u><br>
<img src="cid:part1.03020704.04070505@matrox.com" alt=""><br>
<br>
and the log displays the following: <br>
<br>
<font face="Courier New" size="-1">!ENTRY org.eclipse.osgi 4 0
2008-07-08 12:50:12.941</font><font size="-1"><br>
</font><font face="Courier New" size="-1">!MESSAGE Application error</font><font
size="-1"><br>
</font><font face="Courier New" size="-1">!STACK 1</font><font size="-1"><br>
</font><font face="Courier New" size="-1">java.lang.IllegalStateException:
Unable to acquire application service. Ensure that the
org.eclipse.core.runtime bundle is resolved and started (see
config.ini).</font><font size="-1"><br>
</font><font face="Courier New" size="-1">&nbsp;&nbsp;&nbsp; at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74) </font><font
size="-1"><br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382) </font><font
size="-1"><br>
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179) </font><font
size="-1"><br>
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)</font><font
size="-1"><br>
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)</font><font
size="-1"><br>
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)</font><font
size="-1"><br>
java.lang.reflect.Method.invoke(Unknown Source)</font><font size="-1"><br>
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) </font><font
size="-1"><br>
org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)</font ><font
size="-1"><br>
org.eclipse.equinox.launcher.Main.run(Main.java:1236)</font ><br>
<br>
<br>
My config.ini looks as follows and the org.eclipse.core.runtime plugin&nbsp;
is included in the product configuration.<br>
config.ini built with 3.4:<font face="Courier New" size="-1"><br>
<br>
#Product Runtime Configuration File<br>
osgi.splashPath=platform:/base/plugins/com.matrox.fdk.core<br >
eclipse.product=com.matrox.fdk.core.product<br>
osgi.bundles.defaultStartLevel=4<br>
osgi.bundles=org.eclipse.equinox.transforms.hook@4</font><br>
<br>
<br>
as if the application wanted to start, but terminated before the
workbench could kick in. <br>
config.ini built with 3.3:<br>
<a class="moz-txt-link-abbreviated" href="mailto:osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start">osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start</a><br>
</font><br>
How can this problem be resolved?<br>
<br>
Thanks, <br>
<br>
Mircea<br>
<br>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot.jpg"
Content-ID: <part1.03020704.04070505@matrox.com>
Content-Disposition: inline;
filename="moz-screenshot.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAB3AW0DASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDmtQ8R3XiDVp9TmZt0jHy0 Y58qPPyoOBwP
oM9epNSx6jcIOH/QVhacuIE+lesx+BLMeI7O1kVRatpoeTMh5uMBMdcj52Q4 6V9/Wr0cJBRl
tZ2Xoj5Z0J16jce6/F2OFOs3A483+VMOtXX/AD0/QVnOjK7Ky7WBwQexpMGu xQj2Obks7M0f
7auv+en6Cj+2rr/np+grOwaMGnyLsHKjR/tq6/56foKP7auv+en6Cs7BowaO Rdg5UaP9tXX/
AD0/QUf21df89P0FZ2KTFHIuwcqNL+2rr/np+go/tq6/56foKzcUuDRyLsHK jR/tq6/56foK
P7auv+en6Cs7BowaORdg5UaP9tXX/PT9BR/bV1/z0/QVnYNGDRyLsHKjS/tu 6/56H8qP7buv
+eh/Ks3FJilyLsFkaf8Abd1/z0P5Uf23df8APQ/lWZijFHIuwWRp/wBt3X/P Q/lR/bd1/wA9
D+VZmKMUci7BZGn/AG3df89D+VH9t3X/AD0P5VmYoxRyLsFkaf8Abd1/z0P5 Uf23df8APQ/l
WZijFHIuwWRp/wBt3X/PQ/lR/bd1/wA9D+VZmKMUci7BZGkdbuv+eh/IUf23 df8APQ/kKzcU
bafIuwWRpf23df8APQ/kKP7buv8AnofyFZu2jbRyLsFkaX9t3X/PQ/kKP7bu v+eh/IVm7aNt
HIuwWRpf23df89D+Qo/tu6/56H8hWbto20ci7BZGl/bd1/z0P5Cj+27r/nof yFZu2jbRyLsF
kaX9t3X/AD0P5Cj+27r/AJ6H8hWbto20ci7BZGl/bd1/z0P5Ck/tu6/56H9K zttNZT2o5F2H
yo7Pw/pt7rlnJeSX729uJDGvlxCRmYAFuCygABl5z3+tXn0JFyG1u+/8F8f/ AMeqLwrMYPCs
ODgte3I/8hwV20Wj2fiiCO/hEliITsvIoo2YMAM5jwD8x4GOeucH+L4XM84x tLGVKNGSSi9F
ZdvNH2eXZPgp4SFavFvmvd3ffyOBn0VZmW2ttYuXupSEhjnslRHcnAUsJGIy eM46+nWsfwx8
VLjwjbTWctkb62dg0MXneWITzux8rcHIOOACCe5rrmv7W/8AGWlPZWaWlql7 bRxIPvECRfmb
1Y9/69T4fqKnzV/GurKMbVzKhVjiWpKLVtLd+1uxGZZdRwFam6EXHmTvrc6j SSgjhd13ICCV
zjI9K7eXxnfXNy8vkJFG+ppfmNZNxAUDEecDg7UPTqO9U/B3w/fxFopu11b7 N5cnlbPs+/Py
q2c7h/erpB8JZl6eIf8AyS/+zr2sZj8udXlrP3o6bPyfbyR8/DDYuzlS2l6e a/VnC3xF3f3N
ysQiE0rSCMNu2ZJOM4GcZ64FV/JFeh/8Kmn/AOhhH/gF/wDZ0h+Esx/5mH/y S/8As6qGd5fG
Kip6Lyf+RlLLcXJttfijz3yR6ijyR6ivQv8AhUs3/Qw/+Sf/ANnR/wAKlm/6 GH/yT/8As6r+
3cB/P+D/AMhf2Ziu34o898keoo8keor0L/hUs3/Qw/8Akn/9nR/wqWb/AKGH /wAk/wD7Oj+3
cB/P+D/yD+zMV2/FHnnkj1o8keteh/8ACpZv+hh/8k//ALOj/hUs3/Qw/wDk n/8AZ0f27gP5
/wAH/kH9mYrt+KPPPJHrR5I9a9D/AOFSzf8AQw/+Sf8A9nR/wqWb/oYf/JP/ AOzo/t3Afz/g
/wDIP7MxXb8Uee+SPUUeSPUV6F/wqWb/AKGH/wAk/wD7Oj/hUs3/AEMP/kn/ APZ0f27gP5/w
f+Qf2Ziu34o898keoo8keor0L/hUs3/Qw/8Akn/9nR/wqWb/AKGH/wAk/wD7 Oj+3cB/P+D/y
D+zMV2/FHnnkj1o8ketehf8ACpJv+hhH/gF/9nR/wqSb/oYB/wCAX/2dP+3c B/P+D/yD+zMV
2/FHnvkj1o8ketehf8Kkm/6GAf8AgF/9nR/wqSb/AKGAf+AX/wBnR/buA/n/ AAf+Qf2Ziu34
o898ketHkj1r0L/hUk3/AEMA/wDAL/7Oj/hUk3/QwD/wC/8As6P7dwH8/wCD /wAg/szFdvxR
575I9aPJHrXoX/CpJv8AoYB/4Bf/AGdH/CpJv+hgH/gF/wDZ0f27gP5/wf8A kH9mYrt+KPPf
JHrR5I9a9C/4VJN/0MA/8Av/ALOj/hUk3/QwD/wC/wDs6P7dwH8/4P8AyD+z MV2/FHnvkj1o
8ketehf8Kkm/6GAf+AX/ANnR/wAKkm/6GAf+AX/2dH9u4D+f8H/kH9mYrt+K PPDCKPJHtXof
/CpJv+hh/wDJL/7Oj/hUk3/Qw/8Akl/9nR/b2A/n/B/5B/ZmK7fijzzyR7Ue SPavQ/8AhUk3
/Qw/+SX/ANnR/wAKkm/6GH/yS/8As6P7ewH8/wCD/wAg/szFdvxR555I9qPJ HtXof/CpJv8A
oYf/ACS/+zo/4VJN/wBDD/5Jf/Z0f29gP5/wf+Qf2Ziu34o888ke1Hkj2r0P /hUk3/Qw/wDk
l/8AZ0f8Kkm/6GH/AMkv/s6P7ewH8/4P/IP7MxXb8UeeeSPajyR7V6H/AMKk m/6GH/yS/wDs
6P8AhUk3/Qw/+SX/ANnR/b2A/n/B/wCQf2Ziu34o888ke1Hkj2r0P/hUk3/Q w/8Akl/9nR/w
qSb/AKGH/wAkv/s6P7ewH8/4P/IP7MxXb8UeeeSPamtCBXov/CpJv+hh/wDJ L/7OkPwjmP8A
zMP/AJJf/Z0f29gP5/wf+Q/7MxXb8Uc/p862vhe1Yn5Uvp95/u7kh259M7Wx 9DW3e+OGle0+
wyJYwWmDDDE2QGxyxz94nJ69ieuSTds/hjqWnSNJY+Lbi1dhhmgtyhI9CRJV z/hCPEv/AEP+
qfk//wAdr4/McNhMViZ14YjlUv7sj63AZjUw2GhRqUOZxvrzLq+xzn9uQa34 20q7gtYrdvtU
ElwIiSpKuGeQ/wB0YBJ+mSTya8h1UBZk/Gve7n4e69eQPBc+OdRmhfho5Edl P1BkxXjHjnRz
4f8AEs2lG4+0eQF/e7Nm7cqt0yfXHWvUyGjh8NCrCFXnlKz2a29fU5czxc8X UpydPkjFNb3P
bvhP/wAinN/19f8AtKOu6rhfhP8A8inN/wBfX/tKOu6rx80/3yp6k4T+DEKK 5TXvFNvpXiOx
s31O1gAMfnWzyIJJhK2xdoPPykbjjtV60128uL+FJNNjis555reOYXO6TfGX 5KbcBSEJzuzy
BjvXCk2rm70N2iuZuvFksHiM6ZFpNzNBHIsUtwkU52syg5BWIx7RuGS0ikc8 cDMtnr+o3ZsP
+JTDGLyE3ILXefLiHl53YT73znAGR8oywzwWe43odDRXKr4tvFEHnaQim8RJ bJFutzOjSIhM
nyAIR5iHALd+eOb2rXWpQ/2OYLeNruWYq8AuCsRPkucF9uSoI67c8A4os1qw NyiuQvfGs1lB
bSHTkkf5/tkUUk0jQBXKEjZCw2kq2C5jBx25xpaZ4glv9dutOltIrYRb/LWS cid1Vgu/ymQf
uznh1ZgehwcgHKxG7RXNy+KpLadpbqwWPTWkmihmWfdK7xBi2Y9uFUiN8HeT wMgZ4mOqa6vl
W50jT/t8u6RI/wC0H8sRLtyWfychssBtCke9FmOxvUVgXniRrTSVvTZb2Mk8 flLL3iEh4JHf
y/bGaSbxBfWj3RutLRY7O2+1XDRXJc7T5m1UGwbm+QZBwBuOCcclmC1Ogork 7LxbqN7EY10N
0vXmWOFJjPDCwKsxJeWBG4CHIVG6r6nGv4dmuZ9HWS8wLjz5g4WQyBSJWGAx AJAxgcDgdBQ4
tbiNWiuavbu/tfEPmXl5e2mn+bHHb+TBFJbzbgAVkO0yIxbcAcqv3OSSQaEH j2WW1uLl9DvV
i2K9sRb3P7zc6qobMIAPzg4jMnAbGcDIk3sVY7SisfRtYudW0ia5ksJLS5jZ k8uVZUViBkFT
JGjFeQM7OoPXFc/Ya/r0cDXt1Y282zT7e4nAvSFCnzCWQeXy5AB24UdBuo5X t/WpN9LncUVz
Vh4rlv8AxA+nrpVytp5kkS3Xkz43JkEsTEIwpKnBEhPI4BJAR9X1GDU7+0sb RL2czs6rcXJi
jjjWOLIBCsckvwAMdSSO5YdtbHTUVzEHiue+MN1YafFJpjSQRvPNclJA0oQj bGEYEASLnLLz
n6mr4vm1VdTthbKDZQWst1J5eoSW0hdGTB+VGDAAn5WO1t3I4GXyu9v67gdj RXEnxfc6c4tY
9Nu9QdZJZJnSOeQqhmkVQvlxOCwCHhig6YPXHbDkUmmgCiiikAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABXzX8XP+Sjah/uxf+i1r6Ur5r+Ln/JRtQ/3Yv/RS 17WRfx5f4f1R
zYr4V6/oz1r4T/8AIpzf9fX/ALSjruq4X4T/APIpzf8AX1/7Sjruq5M0/wB8 qeo8J/BiYtxc
+HZb670We+sftt8Ns9obkCZ8oB93O4fKB0+vvVt7bT7FLYuuxUuCYiWY4kkJ H6lz145rA1SX
z31zSFsryS8upVa2f7FIYlbyowsnmlfLG1l3fezleMnArQuLV7q11qJBetMJ Vki+0/6vzFRG
Uxf7O4D/AIFuriei3/rQ6LXKUuo+C59Ya6/4SCxS9BzIkGrmMOVHJkjWQKxA GDuB4GOgq7p2
reF55LYadq+mzvAgtIRDeK5AbGE4Y5J2cd/lPvVO/Z9R07Wby2SZ4rvSYjC8 UZYuSJThRg5P
zDjB6jiqSwNrK29smoa5dlZi3nahpptzAfKk2sv7mMHDYPfnHryWto+gnrqa Ulp4T0F5Xuby
1tArx/LdX5CwndvRUV3xGCVztUAHb04rUlvdKmNvcyXUBSOI3kU3mYjEe3Bf d90rhuue+a5c
aRrkOr20iSQLqDmKW5umtXlg8zZPuwAynAyqjLcDbmpvEOlnS/DamN3lmPnw vIifMTcE52rz
gGUpgc9uvWi3S4bsfPceBLyJ7l9b04wKTHKY9X2RsXLNtkCyBWyS5AbOOcVs 6dZ6PHcf2hZX
PnNdI0sbG9eZChILNGrMVVSSM7QB09qzryC40WXT7q81HVtUiW5y2bNZWiHl SDIW3iBwSQCS
D26VlS6Pe39/Jc29rJHYzGedbKWLyhMh8nMb9NnmMrvg4Jz8wxuUtJX30H0u zpLXRtEnlbVb
ZVnjuUZwVuGkgYOPmZU3GMFucsBk5PPJzjNJ4HTT493iOFYBKwjnOvyBgwA3 Isnm7gMFcoDj
ocdK6y1uEubOKdI5Y0dAwSWMo6+xU8g+1cfp+qxW1zbXU1lqwhzexnGlXLMC 0yuuVEecFTnO
MdR1BqUruwa7lu/g8GabdkajqNpbSzhpFhudTZFw4ZWZEZ8DdubJUDJJJ5ro nsrSbz3khSRb
iIRSh/mV0GeCDxj5j+dcNbxXGlX+J7nXdNiaFTFBp+mC4QJ5srLGxWGQKVVl XAIr0BmXyixU
su3JG3JI+lOWwbS0Oc07TPDWq2EsWnajJfwJKpMkOrzTNC4HG1xIWjOCRhSM g4PFXDFoOiXd
isk9taXDeZDaLNc7WkMjqzqoY/MSwX1P51V8N30eq3l1ftZ3lpO8aRrBcWM0 HlxKWKgs6gM2
WYkKSBkAZxuNbxIky3Woxi3uZjqOnpa2vk27yqkoaTJYgEIPnQ5YgfL14p68 1rjstfI2pdDs
JNS/tCQXHmhg5X7VKIiwGAxi3bCRgclc8A9hWNbweDjpd7PBqlvJpi4jnI1V nt7c5BUKPM2R
EHGNu0jjGK6lsLEdwLALyAM5/CuR0/V7a6W81S4sNUtpGSOJYhpE/mQRgtsO DH87gsSdoYLk
DkAsZQLa5t6O+lx28Vvp1693FMjTxu93Jdb1yASJHZsjOOM96dbeH9MtLSa1 hgcQTR+U6NM7
fIM4UZJ2gbjgDAA4HQVzU639p4biv7VZUvfMuIoZZ4tkriYkIzK2ArM/lHaQ oB/hUcCrpyXk
emzfab/WLmxM6G4SKxv4J412tnYZJHlYFtmfLOAAfU0+7Fa39f1udTZ6fpEe tTzWksyXauxk
gW7lWMsQCzeTu2E/OpLBerZzmpb7w7pmoszTwyrIzlzJDcSQvkqFI3IwOCFX K5wcDI4rkbp5
rMSTQnWIdOeaM7tlwZmUtbLyCDIWI3jn5vvd81BdpqCxK1tJrslgbiQ2VrKL 1JZBsjHzzKDJ
Hh/MI80MpB7AKQ1G6TBXudFeeFVfXIdRS6S2sYPLke2gWZS5jHykhZRGeijm MnCgA8Ajaktb
HVYVnZBNHNbtGrBiN0b4J6euB71yukR6t/wmEsl7f3iEyyg2zWN0Ymi52AS+ YbccbDkKG4we
SckBji1FLC7/ALTENi4t7VbEXHlq4bcBL5PbY0P3/lxn3pXen3/1+ArJP+vk dDN4a0yaVJfL
uIZEJ+e2u5YWbLFiGKMNw3MxAOQMnHWrWo6na6TbCe7eQKzBFWKJ5XduuFRA WY4BPAPAJ6Cu
LtI9TmeKOGTXUkYRDU2uDMMTecmfKLfIF2+bnyvlxj2q5ceHftNzbW0ras9v a6hIYH+3XAdU
NvnPmB9xG8kAknGSo4OKLaD0vqdjDLHPCk0Th45FDKw6EHkGn154JbqKWzGo Sa4moGSzS2Ia
5EBjIjDByv7vcW8zPmfN07bauC61LUYdMto11iB4oo4rx2iljPmCWHd8xGG+ Xf8AMuRjdg0+
TXQm/c7eokuYJHCRzxsx3YCuCTtOG/I8H0NcXfR6jF4rtVtGv447V4Igm28m WeHIDO0hkEIP
zMCGV3+XdnpivHa3lnFdQWketoqyzm6AeZiUNwhzEWJBJiLEeWc8nHzVKSf9 f1/WhXW3oeg1
ElxFJcS26vmWIKzrjoGzg/ofyrjdP0+51GYwvNrUekYnNsJJ7iGYj91jezES 53+btDHJX1GK
1bRnt5tJnvgxlvbIW9x5ifM8irvAIx1x5vGKGrf16/5CNW91jTNNthc32o2l rAXMYlnnVFLD
OVyTjPB49jVrzosRnzExL/qzuHz8Z49eATXGWWrxaX4ZiSx0i+Qi7lhhX+yb gLbqzMwcxhN2
wKRwo5JC5XkizIunWU3hdoLG8fycxxzf2bMXjjMZXDkJmMFiuQ2PXGBw7B0u bieINFe5ubZN
XsGuLVWe4iFyhaJV+8WGcqB3z0qIeKPD5sDfDXdMNmJPKNx9rj8sPjO3dnGc c4rn0h3Saxp6
PrcmlzQ3TXUUtjt8l3fOIG8sGTO6Q8eZ0HTgGxbajNHpEzXc+uPE05jtL3+y ibpV2AkmJYuB
u3gExgYHuCVZWuU0kb0+vaPbXNvbT6tYRT3IVoIpLlFaUMcKVBOWyemOtS2u q6dfXFxb2d/a
3E9s22eOGZXaI8jDAHKng9fSuSjju7K50trZdTt9Sa2toJbWO032rxqzZ3yF W2FQzn/WA5x9
7vJ4bin/ALUDTx6g0cVm8UkN1Z+WloxZSY4n2jzlOOuX+4Du+bBdl08watt5 HT3usaZptsLm
+1G0tYC5jEs86opYZyuScZ4PHsafLqenw3Ftby31tHPdZ+zxtKoabHJ2DOW6 jpXJ2WrxaX4Z
iSx0i+Qi7lhhX+ybgLbqzMwcxhN2wKRwo5JC5XkivY211p2qxvp8uphZjbR2 0B04CJ7ZVUN5
rtEGjZSZWCl15IwpyQS2oraHZf2vpvn3UH9oWnm2a77mPzl3QLjOXGflGOcm pLS+tNQs1u7K
6hubZ8lZoJA6Ng4OCODyDXB2Vrq1vp4sfM1G4WDy7i/jmsljRJFnSRxCyRr5 u8eaTjeTxkgn
DdHpd0267nWzvRDqN63kh7ZozGohALOrAMoLRsBkZJYdiDQ1o2v6/wCH/QbR u288d1bRXELb
opUDo2CMgjIPNSVwFpHqUM9hGE1ZNQQ2q26ETC0FuETzQ+392G/1v3/nzjH8 NS6JfGzvvMkX
Xpr6PT5Zb63nFwwklVkyIlfEZ53AeV8vI7EU+TXT+v6/Mnb8PxO6r5r+Ln/J RtQ/3Yv/AEUt
fSgORmvmv4uf8lG1D/di/wDRS16+R/x5f4f1RzYn4V6/oz1r4T/8inN/19f+ 0o67quF+E/8A
yKc3/X1/7Sjruq5M0/3yp6lYT+DEKKKK4DoGoiRIEjVURRgKowBTqKKACmui SLtdVZcg4YZH
HIp1FABRRRQBlXvhjQNSumur7Q9Murlsbpp7SN3OBgZJGelagAAAAwB0ApaK ACslvC/h9r/7
c2haYbzzPN+0G0j8zfnO7djOc85rWooAq6hplhq1uLfUbG2vIAwYR3ESyKG9 cMCM8mk0/StO
0mBoNNsLWyiZt7R20KxqW6ZIUDngVbooAyW8L+H2v/tzaFphvPM837QbSPzN +c7t2M5zzmta
iigBroki7XVWXIOGGRxyKdRRQA2SKOVQsiK4DBgGGcEHIP1B5p1FFABTVRFZ mVVDMcsQOT25
p1FABRRRQBTbSNNfU01N9OtG1BBtW6MKmVRgjAfGQMEjr3q5RRQAUUUUAFNZ EcqWVWKncuRn
B9RTqKACiiigAooooAKKKKACiiigAooooAKp2Wkabpkk8lhp1paSXB3TNBCs ZkPPLEDk8nr6
mrlFABXzX8XP+Sjah/uxf+ilr6Ur5r+Ln/JRtQ/3Yv8A0Ute1kX8eX+H9Uc2 K+Fev6M9a+E/
/Ipzf9fX/tKOu6rhfhP/AMinN/19f+0o67quTNP98qeo8J/BiFFFFcB0BRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQBxWltczeHNFvr/xbrgvNQ09Lww21rauT+6DuVRb Zm2jIHfllXJL
AG68Eke/d4n8VHZuzt06Bum/OMWnP+rbGOuUxnem48KPjQ/CEfmY3aBG2zfj OEt+du8Zxnrs
bGfvLnD9RVN6iOXeCSPfu8T+Kjs3Z26dA3TfnGLTn/VtjHXKYzvTcPBJHv3e J/FR2bs7dOgb
pvzjFpz/AKtsY65TGd6buorL8QXMtro8kkUxgzJGjzAZMSM6qze2FJOTwOp4 FCd3YLGW8Eke
/d4n8VHZuzt06Bum/OMWnP8Aq2xjrlMZ3puHgkj37vE/io7N2dunQN035xi0 5/1bYx1ymM70
3UdVE+g3sdppFxeXJlWOV7e5v3lKt58ar88hZlVwzg84whwM5z0Hh8+Zp7XD 3U09zLITceaS
PLkHBRUyQgXGMD65YksX0uDVjNeCSPfu8T+Kjs3Z26dA3TfnGLTn/VtjHXKY zvTcPBJHv3eJ
/FR2bs7dOgbpvzjFpz/q2xjrlMZ3pu6iipuBy7Q+XIqS+LvEcW6UQh5bO2RN 5ZlUbjagcshA
553Jj76bm+BtSvtRt9ZW+vJbs2upPBDJKsYcR+VGwB2KoJyx5wK3NXfy7KNv M2Zurdc79vWZ
BjO9OucYyc5xtfOxuZ+HX+q8R/8AYYf/ANEQ073QHaUUUVIwooooAKKKKACi iigAooooAKKK
KACiiigAooooAK+a/i5/yUbUP92L/wBFrX0pXzX8XP8Ako2of7sX/opa9rIv 48v8P6o5sV8K
9f0Z618J/wDkU5v+vr/2lHXdVwvwn/5FOb/r6/8AaUdd1XJmn++VPUeE/gxC iiiuA6AooooA
KKKKACiiigAooooAKKKKACiiigAooooA4PQtftbbwt4Ya3vrJ5INGiilgluJ EG4wxleVDLkM
gU5UkBiQRgq+s/i6Eb/Ll0xsbtm68cZ+/tz+6OM4iz1xvfrsG+z/AMIT4U/6 FjRf/ACL/wCJ
o/4Qnwp/0LGi/wDgBF/8TTbTEVn8XQjf5cumNjds3XjjP39uf3RxnEWeuN79 dg3pL4ttysir
JpbqQwUPduAw+fGf3RxnEWeuN79dg32v+EJ8Kf8AQsaL/wCAEX/xNH/CE+FP +hY0X/wAi/8A
iaNAMi21TRNMglg02x8P28JcyCOKQxKzjfsYhYcA/LDzzjc2M7Bvtf8ACTWU MtxLbjSBJKSW
f7U6mUgOFLEReiwjvjc3XYN93/hCfCn/AELGi/8AgBF/8TR/whPhT/oWNF/8 AIv/AImjQCs/
i6Eb/Ll0xsbtm68cZ+/tz+6OM4iz1xvfrsG8fxdCN/ly6Y2N2zdeOM/f25/d HGcRZ643v12D
fZ/4Qnwp/wBCxov/AIARf/E0f8IT4U/6FjRf/ACL/wCJo0Ap3Hia3uSkX23T 4YhOjtIt1KW2
LIzdFVeSFjGN2PnbO4LiSn8OGDQeImUgqdXYgjv+4hrY/wCEJ8Kf9Cxov/gB F/8AE1pafpen
6Tbtb6bYWtlCzb2jtoVjUtgDJCgDOAOfagC3RRRSGFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABXzX8Xf+Sjah/uxf8Aota+lK+a/i5/yUbUP92L/wBFLXtZF/Hl/h/V HNivhXr+jNfw
l8Vbbwxo7WLaXJcM0vmFhMEA+VVx90/3f1rd/wCF823/AEAZP/Aof/EUUV7t XAYarN1Jwu35
v/M5YSnCPLF6fL/IP+F823/QAk/8Cv8A7Cj/AIXzbf8AQAk/8Cv/ALCiis/7 Mwf/AD7/ABl/
mV7Wp/N+X+Qf8L5tv+gBJ/4Ff/YUf8L5tv8AoASf+BX/ANhRRR/ZmD/59/jL /MPa1P5vy/yD
/hfNt/0AJP8AwK/+wo/4Xzbf9ACT/wACh/8AEUUUf2Zg/wDn3+Mv8w9rU/m/ L/IP+F823/QA
k/8AAr/7Cj/hfNt/0AJP/Ar/AOwooo/szB/8+/xl/mHtan835f5B/wAL5tv+ gBJ/4FD/AOIo
/wCF823/AEAJP/Ar/wCwooo/szB/8+/xl/mHtan835f5B/wvm2/6AEn/AIFD /wCIo/4Xzbf9
ACT/AMCv/sKKKP7Mwf8Az7/GX+Ye1qfzfl/kH/C+bb/oASf+BX/2FH/C+bb/ AKAEn/gV/wDY
UUUf2Zg/+ff4y/zD2tT+b8v8g/4Xzbf9ACT/AMCv/sKP+F823/QAk/8AAr/7 Ciij+zMH/wA+
/wAZf5h7Wp/N+X+Qf8L5tv8AoASf+BX/ANhR/wAL5tv+gBJ/4Ff/AGFFFH9m YP8A59/jL/MP
a1P5vy/yD/hfNt/0AJP/AAKH/wARR/wvm2/6AEn/AIFD/wCIooo/szB/8+/x l/mHtan835f5
B/wvm2/6AEn/AIFf/YUf8L5tv+gBJ/4Ff/YUUUf2Zg/+ff4y/wAw9rU/m/L/ ACD/AIXzbf8A
QAk/8Cv/ALCj/hfNt/0AJP8AwK/+wooo/szB/wDPv8Zf5h7Wp/N+X+Qf8L5t v+gBJ/4Ff/YU
f8L5tv8AoASf+BX/ANhRRR/ZmD/59/jL/MPa1P5vy/yD/hfNt/0AJP8AwK/+ wo/4Xzbf9ACT
/wACv/sKKKP7Mwf/AD7/ABl/mHtan835f5B/wvm2/wCgBJ/4Ff8A2FH/AAvm 2/6AEn/gV/8A
YUUUf2Zg/wDn3+Mv8w9rU/m/L/IP+F823/QAk/8AAr/7Cj/hfNt/0AJP/Ar/ AOwooo/szB/8
+/xl/mHtan835f5B/wAL5tv+gBJ/4Ff/AGFH/C+bb/oASf8AgV/9hRRR/ZmD /wCff4y/zD2t
T+b8v8g/4Xzbf9ACT/wK/wDsKP8AhfNt/wBACT/wK/8AsKKKP7Mwf/Pv8Zf5 h7Wp/N+X+Qf8
L5tv+gBJ/wCBQ/8AiKP+F823/QAk/wDAr/7Ciij+zMH/AM+/xl/mHtan835f 5B/wvm2/6AEn
/gV/9hR/wvm2/wCgBJ/4Ff8A2FFFH9mYP/n3+Mv8w9rU/m/L/IP+F823/QAk /wDAr/7Cj/hf
Nt/0AJP/AAK/+wooo/szB/8APv8AGX+Ye1qfzfl/kH/C+bb/AKAEn/gV/wDY V5h4x8Qp4p8S
XGrJbm3EwQeUX3Y2qF64HpRRW1HCUKEnKlGzem7/AFbJlKUvid/uP//Z
--------------040801070208000606020102--
--------------000708030006010509040705--
Re: Cannot start RCP product exported under Eclipse 3.4 [message #329870 is a reply to message #329859] Tue, 08 July 2008 16:50 Go to previous message
--------------050703090109040109040205
With some inspection, I came to the conclusion that the default
config.ini file generated by Eclipse 3.4 during an RCP product export is
not complete.
In essence, there are osgi bundles missing from the osgi_bundles= line.
I compared the versions generated by 3.3 and 3.4 and
the org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
parameters are missing.
I changed the original 3.4 config.ini from
*_osgi.bundles=org.eclipse.equinox.transforms.hook@4_**_
_*
to
*_osgi.bundles=org.eclipse.equinox.transforms.hook@4,org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start_**_
_*
and everything works as expected.
I will write a bugzilla.
Mircea
Mircea Luchian wrote:
> Hello,
> !STACK 1
> service. Ensure that the org.eclipse.core.runtime bundle is resolved
> and started (see config.ini).
> at
> at
> at
> plugin is included in the product configuration.
> located below, however, when I copied the same parameters in the
> config.ini of the RCP app build with Eclipse 3.4, the application
> failed to start properly. The splash screen was appearing and
> disappearing repeatedly as if the application wanted to start, but
> terminated before the workbench could kick in.
> Mircea
boundary="------------030709060100000806070100"
--------------030709060100000806070100
<html>
<head>
</head>
Hello, <br>
<br>
is not complete. <br>
I compared the versions generated by 3.3 and 3.4 and the&nbsp;<font
face="Courier New, Courier, monospace" size="-1"><a class="moz-txt-link-abbreviated" href="mailto:org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start">org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start</a></font><font
face="Courier New" size="-1"> </font>parameters are missing. <br>
<br>
I changed the original 3.4 config.ini from <br>
<br>
<font face="Courier New" size="-1">#Product Runtime Configuration File<br>
<b><u>osgi.bundles=org.eclipse.equinox.transforms.hook@4</u></b></font><b><u><br>
</u></b><br>
to<br>
<br>
<b><u><a class="moz-txt-link-abbreviated" href="mailto:osgi.bundles=org.eclipse.equinox.transforms.hook@4,org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start">osgi.bundles=org.eclipse.equinox.transforms.hook@4,org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start</a></u></b></font><b><u><br>
</u></b><br>
and everything works as expected.<br>
I will write a bugzilla. <br>
<br>
Mircea<br>
<br>
<br>
<blockquote cite="midg506nv$bg5$1@build.eclipse.org" type="cite">
Hello, <br>
<br>
<img src="cid:part1.07050008.09010409@matrox.com" alt=""><br>
<br>
<br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
size="-1"><br>
<br>
<br>
<br>
<br>
<br>
</font><br>
<br>
Thanks, <br>
<br>
Mircea<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Content-ID: <part1.07050008.09010409@matrox.com>
--------------030709060100000806070100--
--------------050703090109040109040205--
Previous Topic:Removing menu items that were added by org.eclipse.search
Next Topic:Overiding/deactivating extension org.eclipse.search.searchPages
Current Time: Mon Nov 17 02:25:37 EST 2025
Powered by FUDForum. Page generated in 0.08680 seconds
