Home » Eclipse Projects » Eclipse Platform » Contribution to Eclipse toolbar is not hidden on switching the perspective
Contribution to Eclipse toolbar is not hidden on switching the perspective [message #329843] Tue, 08 July 2008 06:24 Go to next message
we've an issue with contributing a toolbar to the Eclipse main toolbar. We
do want to have the additional toolbar visible only within our own
perspectives, but not in the standard perspectives. However, the toolbar,
once contributed, is staying visible in all perspectives.
<menuContribution
locationURI="toolbar:org.eclipse.ui.main.toolbar?after=additions ">
<toolbar id="myToolbarId">
<command>
</command>
<visibleWhen>
... see below ...
</visibleWhen>
</toolbar>
</menuContribution>
We've played with two variants of the <visibleWhen> expression:
a) Testing for the active perspective id...
<visibleWhen>
<with variable="activeWorkbenchWindow.activePerspective">
<or>
<equals value="myPerspective1"/>
<equals value="myPerspective2"/>
<equals value="myPerspecitve3"/>
</or>
</with>
</visibleWhen>
b) Testing for an actionSet within the active contexts which is bound via
perspectiveExtentsions to the desired perspectives...
<visibleWhen>
<with variable="activeContexts">
<iterate operator="or">
<equals value="myActionSetId"/>
</iterate>
</with>
</visibleWhen>
None of those approaches are working. The toolbar is visible in all
perspectives. Any ideas or suggestions on how to solve this issue? We are
using the final Eclipse 3.4 build.
Thanks, Regards,
Uwe Stieber
Re: Contribution to Eclipse toolbar is not hidden on switching the perspective [message #329852 is a reply to message #329843] Tue, 08 July 2008 11:23 Go to previous messageGo to next message
The visibleWhen will not work against the toolbar:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=201589
Will it work for you if applied to the command?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Contribution to Eclipse toolbar is not hidden on switching the perspective [message #329856 is a reply to message #329852] Tue, 08 July 2008 12:00 Go to previous message
Hi Paul,
Yes, it works if applying the visibleWhen expression to the command itself.
Thanks for the hint.
Uwe Stieber
> PW
> Paul Webster
Previous Topic:Source -> Format menu
Next Topic:No more handles [gtk_init_check() failed]
Current Time: Tue Nov 04 11:38:24 EST 2025
Powered by FUDForum. Page generated in 0.03467 seconds
