Home » Eclipse Projects » Eclipse Platform » Not able to retieve correct data based on date!
Not able to retieve correct data based on date! [message #329828] Mon, 07 July 2008 10:05 Go to next message
Originally posted by: santoshkumar_m.persistent.co.in
Hi Jason,
I tried with the following workarounds for the date range problem.
1. I tried with the following two sets of expression builders
i) getStartDateFromGroupNames("Report Period","Begin Date","End Date")
getEndDateFromGroupNames("Report Period","Begin Date","End Date")
getReportPeriodFromGroupNames("Report Period","Begin Date","End Date")
for this i got errors:
The following items have errors:
Error evaluating Javascript expression. Script engine error:
ReferenceError: "getNLS" is not defined.
Script source: source, line: 0, text:
getNLS(params["Report Period"].value)
ReferenceError: "getStartDate" is not defined.
(params["Begin Date"].value != null && params["Begin Date"].value !=
"")?params["Begin Date"].value:getStartDate(params["Report Period"].value)
ReferenceError: "getEndDate" is not defined.
(params["End Date"].value != null && params["End Date"].value !=
"")?params["End Date"].value:getEndDate(params["Report Period"].value)
ii) (params["Begin Date"].value != null && params["Begin Date"].value !=
for this also i got the similar errors:
ReportDesign (id = 1):
+ Error evaluating Javascript expression. Script engine error:
ReferenceError: "getReportPeriodFromGroupNames" is not defined.
ReferenceError: "getStartDateFromGroupNames" is not defined.
ReferenceError: "getEndDateFromGroupNames" is not defined.
2. I added the library “TivoliCommonReporting_v1.0.rptlibrary” to that
column binding.
Can you post your report?
Have you tied the date report parameters to the dataset parameters?
Jason
Santhosh Kumar wrote:
Hi Birters,
I am using BIRT-2.2.1. I ma new to this tool. I have one issue here. I am
trying to create a report such that it should retrieve the data, from the
data base to which it is connected, for a selected period and it should
show the data in a table or chart. Here, that time perid should be
provided by the user as an input paramaeter. I have created Report
parameter for "Bgin Date" and "End date" and for "report period" (like,
today, yesterday, weekly, last 30 days, last 1 week, last month, last
quarter, yearly). So, here I am not able to retrieve the correct data
according to the time slot given by the user.
That is there is no impact of report parameters on data.
Please suggest me solution for this.
Early suggestions is appriciated.
Thanks & Regards,
Santhosh Kumar
Re: Not able to retieve correct data based on date! [message #329842 is a reply to message #329828] Tue, 08 July 2008 03:43 Go to previous message
Please! Anybody could give the solution for this issue.
I stucked up here. It is very urgent to resolve.
santhosh
Previous Topic:feature size problem with p2
Next Topic:Invisible Plugin Architecture
Current Time: Mon Sep 15 17:14:17 EDT 2025
Powered by FUDForum. Page generated in 0.04799 seconds
