using XML editor [message #329816] |
Mon, 07 July 2008 18:30 |
Originally posted by: dave.dave.net
I am writing a XML related project that will cater for my specific
specification setup. I am thinking about using the XML editor (I am
mainly interested in the text formating and the options)found in the
eclipse platform. Have anyone extended this package for their own use ?
I am having trouble finding the specific package that the editor is
found (i think its org.eclipse.wst.xml.ui but I can't find the source
when I import the project) ??
Thanks, David
Re: using XML editor [message #329823 is a reply to message #329816] |
Mon, 07 July 2008 07:59  |
David,
It's probably best to ask on the WTP newsgroup, which I've added to the
"to" list of the reply.
David wrote:
> Hi
> ? I am having trouble finding the specific package that the editor is
> Thanks, David
Re: using XML editor [message #329834 is a reply to message #329823] |
Mon, 07 July 2008 16:44  |
I've been wondering for some time why platform doesn't have an XML
editor on it's own to improve OOTB experience. Ant editor is part of the
platform but already specialized as it seems to imply a specific DTD.
Any ideas why this isn't refactored into a simple platform XML editor,
specific Ant editor built on top and an advanced WST editor?
Andi
Ed Merks wrote:
> David,
> David wrote:
>> Hi
>> Thanks, David
Re: using XML editor [message #329836 is a reply to message #329834] |
Mon, 07 July 2008 16:47  |
Andreas,
I think it's a basic lack of resource. There's also a lot of drive to
keep the platform smaller rather than allowing it to grow bigger and
bigger. On could certainly argue that installing the JEE package gives
you the out of the box experience you need if you want an XML editor
(though that doesn't help provide an ant editor build on the WST XML
editor).
> the platform but already specialized as it seems to imply a specific DTD.
> Cheers,
> Andi
> Ed Merks wrote:
>> David,
>> David wrote:
>>> Hi
>>> Thanks, David
Re: using XML editor [message #329837 is a reply to message #329836] |
Mon, 07 July 2008 17:21  |
Even more- platform has this editor already- it's just not exposed as
such. Ant editor capabilities are just fine, just a little too much with
the DTD applied...
In consolidation with WTP were possible it would even decrease overall
code size.
Andi
Ed Merks wrote:
> Andreas,
> editor).
>> Cheers,
>> Andi
>> Ed Merks wrote:
>>> David,
>>> David wrote:
>>>> Hi
>>>> Thanks, David
FUDForum. Page generated in 0.03233 seconds
