Paths in Plugin [message #329761] |
Thu, 03 July 2008 07:30 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: automatic.javalobby.org
I´m new to the plugin development.
Now I have the following problem.
I want to call from an action a CheckedTreeSelectionDialog.
For this I use the following code:
public void run(IAction action) {
Shell shell = new Shell();
CheckedTreeSelectionDialog treeDialog = new CheckedTreeSelectionDialog(shell, new TreeLabelProvider(), new TreeContentProvider());
treeDialog.setInput(ContentProvider.getInitalInput());
int returnV =treeDialog.open();
The TreeLabelProvider has the following constructor:
// Images for tree nodes
private Image file;
private Image dir;
* Constructs a FileTreeLabelProvider
public TreeLabelProvider() {
// Create the list to hold the listeners
listeners = new ArrayList();
// Create the images
try {
file = new Image(null, new FileInputStream("icons/full/obj16/file_obj.gif"));
dir = new Image(null, new FileInputStream("icons/full/obj16/fldr_obj.gif"));
} catch (FileNotFoundException e) {
e.printStackTrace();
In this constructor I use relative paths. But with these paths I get a file not found Exception
How can I get the absolute Path at this point in my program code?
Re: Paths in Plugin [message #329763 is a reply to message #329761] |
Thu, 03 July 2008 08:46 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Alwin
You can either use FileLocator.find() from the plugin org.eclipse.equinox.common or for images you can also use AbstractUIPlugin.imageDescriptorFromPlugin().
Cheers, Stephan
Re: Paths in Plugin [message #329771 is a reply to message #329763] |
Thu, 03 July 2008 12:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I tried now to create the image with this code:
Image file=AbstractUIPlugin.imageDescriptorFromPlugin(
"de.itm.inkas.svn.popUpMenu", "icons/full/obj16/file_obj.gif").createImage();
But I still get the FileNotFound Exception:
java.io.FileNotFoundException: icons\full\obj16\file_obj.gif (Das System kann den angegebenen Pfad nicht finden)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at de.itm.inkas.svn.filecomponent.FileNode.getImage(FileNode.ja va:25)
at de.itm.inkas.svn.filecomponent.TreeLabelProvider.getImage(Tr eeLabelProvider.java:80)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.getImag e(WrappedViewerLabelProvider.java:117)
at org.eclipse.jface.viewers.WrappedViewerLabelProvider.update( WrappedViewerLabelProvider.java:165)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn. java:135)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:911)
at org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:97)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:991)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:466)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:2026)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( AbstractTreeViewer.java:806)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewer.java:781)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( AbstractTreeViewer.java:755)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeView er.java:627)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpan d(AbstractTreeViewer.java:1410)
at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeVi ewer.java:918)
at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded( AbstractTreeViewer.java:1421)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:125)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:947)
at org.eclipse.swt.widgets.Tree.wmNotifyChild(Tree.java:7053)
at org.eclipse.swt.widgets.Control.wmNotify(Control.java:4563)
at org.eclipse.swt.widgets.Composite.wmNotify(Composite.java:15 81)
at org.eclipse.swt.widgets.Control.WM_NOTIFY(Control.java:4216)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3724 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1541)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:5798)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3705 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5370)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4364 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:22 65)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3291)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.dialogs.CheckedTreeSelectionDialog.open(Check edTreeSelectionDialog.java:241)
at de.itm.inkas.svn.menu.actions.BrowseAction.run(BrowseAction. java:43)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Re: Paths in Plugin [message #329787 is a reply to message #329761] |
Thu, 03 July 2008 18:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: Jim.Cooper.sas.com
The best way I've found for use in a plug-in (or any Jar, for that
matter), if the images are inside, is to use something like this:
ImageIcon folderIcon = new
ImageIcon(getClass().getResource("/images/icons/folder.png"));
Adjust as needed to get an Image object rather than an ImageIcon.
Alwin Schmitz wrote:
> Hello,
> private Image file;
> private Image dir;
> try {
FUDForum. Page generated in 0.03717 seconds
