PDE Build, test fragments, and build cycles [message #329753] |
Wed, 02 July 2008 15:59 |
Chris W![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=chris%40firestruck.com) Messages: 33 Registered: July 2009 |
Member |
Hey there. Has anyone found a workaround PDE Build's build cycle
limitation?
Currently PDE Build makes only one pass at building a given feature's
plugins. PDE Build also requires that only one non-binary dependency is
allowed - in other words, plugins can have only one to-be-compiled
dependency, but all others must be pre-compiled.
We have test fragments for each plugin that makes up our RCP application.
Our test suite also contains a common plugin that provides utils to these
tests fragments. The snag is that this common test plugin depends on a
couple plugins that make up the RCP app. So...
RCP Plugin A --hosts--> Fragment A
Fragment A --depends--> Test Common Plugin
Test Common Plugin --depends--> RCP Plugin B
RCP Plugin B --depends--> RCP Plugin A
Crazy, I know, and, naturally, PDE doesn't like this. Within Eclipse,
"JDT handles cycles by appending a build loop after normal build action in
presence of cycles. The loop keeps building incrementally until no more
structural changes is detected in generated classfiles". (See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=208011#c13.)
It's looking like we need to be creative with our test packaging. My
current thinking is that we have to break up the Test Common Plugin
migrating the contents to our core RCP plugin which every RCP plugin
depends. This way all test fragments will have access to test utils.
Any ideas?
Swimming in circles,
Chris
FUDForum. Page generated in 0.02736 seconds
