Home » Eclipse Projects » Eclipse Platform » "Open" menu action in Project Explorer
"Open" menu action in Project Explorer [message #329711] |
Tue, 01 July 2008 12:40  |
I am trying to override the "Open" action in the context menu of the
Project Explorer to use my own custom action instead, which opens a
resource in a custom editor and sets additional properties as well.
I am not sure which extension point to use for this - my initial thought
would be popupMenus.
The resources of interest are of type IFile, and have no extension because
they are linked to a file system that does not require an extension. They
are of a certain Project Nature type, however - but I am not sure how to
check for this in an extension point. I only want the "Open" action to be
overridden for files within projects of my custom Nature.
Any help will be appreciated.
Derek
Re: "Open" menu action in Project Explorer [message #329758 is a reply to message #329730] |
Wed, 02 July 2008 17:28   |
Thanks for the reply!
The link helped me greatly, thanks for that. I don't quite understand
what is supposed to happen from the code in the article are though - the
author sets the global action handler on the open action, which I assumed
would retarget the Open action in the context menu. I get confused when
the author then appends his custom open action to the "Open Group" of the
context menu - why would this need to be done if he is retargetting the
global Open action? I dont want to add a new action, I want to override
the functionality of the existing one.
I did implement it however, and saw that my open action did not get called
when the Open action was selected in the context menu. When I appended my
action to the "Open Group", my action appeared in the Context menu above
the global open action. Is this correct? Again, I thought my custom
action would just get called when the global action was selected, rather
than adding a new action.
I also am not understanding how to use <enablement> with my action
provider extension - I get as far as "instanceof IFile", but how do I tell
it only IFile's of a certain Project Nature?
Derek
Re: "Open" menu action in Project Explorer [message #329790 is a reply to message #329758] |
Fri, 04 July 2008 05:34   |
Hi sorry for a late reply, I happened to check this today only...
Regarding the enablement clause:
<enablement>
<or>
<and>
<adapt type="org.eclipse.core.resources.IResource/IFile" />
<test
property="org.eclipse.core.resources.projectNature"
value="">
</test>
</and>
</or>
</enablement>
You need to add your own action and this needs to go into the "Open Group".
However, if you find that there are two "Open" actions coming up, that is
not the expected behavior. Can you post code from your plugin.xml where you
have contributed the actionProvider and also snippets from your class
implementing the commonActionProvider. Maybe we can identify what's going
wrong.
Rahul
"Derek. R" <spadge248@yahoo.com> wrote in message
news:806ed4676af95918da0c41122aa60762$1@www.eclipse.org...
> Derek
Re: "Open" menu action in Project Explorer [message #329853 is a reply to message #329790] |
Tue, 08 July 2008 11:27   |
Here is my plugin.xml code:
<extension point="org.eclipse.ui.navigator.navigatorContent">
<actionProvider
class="my.plugin.name.ui.actions.PropertyActionProvider"
id="my.plugin.name.ui.actions.OpenProvider">
<enablement>
<and>
<instanceof
value="org.eclipse.core.resources.IFile">
</instanceof>
<test
value="'my.plugin.name.core.natures.myNature' ">
</test>
</and>
</enablement>
</actionProvider>
</extension>
<extension point="org.eclipse.ui.navigator.viewer">
<viewerActionBinding
viewerId="org.eclipse.ui.navigator.ProjectExplorer">
<includes>
<actionExtension
pattern="my.plugin.name.ui.actions.OpenProvider">
</actionExtension>
</includes>
</viewerActionBinding>
</extension>
This seems to be working, thanks for the example below. I still see my
open action along with the global open action, however. Here is a snippet
of my commonActionProvider:
public class PropertyActionProvider extends CommonActionProvider
OpenEditorAction m_openAction;
public void fillActionBars(IActionBars actionBars)
if (m_openAction.isEnabled())
actionBars.setGlobalActionHandler(ICommonActionConstants.OPE N,
m_openAction);
public void fillContextMenu(IMenuManager menu)
menu.appendToGroup(ICommonMenuConstants.GROUP_OPEN, m_openAction);
It is very similar to the example given in the article you suggested,
which is why I am stumped as to what is wrong.
Derek
> <enablement>
> <or>
> <and>
> <test
> value="">
> </test>
> </and>
> </or>
> </enablement>
> wrong.
> Rahul
>> Thanks,
>> Derek
Re: "Open" menu action in Project Explorer [message #329901 is a reply to message #329853] |
Thu, 10 July 2008 05:19   |
In your plugin.xml, put the following and see:
overrides="org.eclipse.ui.navigator.resources.OpenActions"
This should be in the actionProvider declaration after you declare the class
and id... so:
<extension point="....navigatorContent">
<actionProvider
class="..."
id="....."
overrides="org.eclipse.ui.navigator.resources.OpenActions">
Try this and let me know. Rest of the code looks fine.
Rahul
"Derek R." <spadge248@yahoo.com> wrote in message
news:5d6913f6a98a9c197e53c44f9703c4b8$1@www.eclipse.org...
> <actionProvider
> <enablement>
> <and>
> <instanceof
> </instanceof>
> <test
> </test>
> </and>
> </enablement>
> </actionProvider>
> </extension>
> <includes>
> <actionExtension
> </actionExtension>
> </includes>
> </extension>
> m_openAction);
> Derek
>> <enablement>
>> <or>
>> <and>
>> <test
>> value="">
>> </test>
>> </and>
>> </or>
>> </enablement>
>> Group". However, if you find that there are two "Open" actions coming up,
>> that is not the expected behavior. Can you post code from your plugin.xml
>> where you have contributed the actionProvider and also snippets from your
>> class implementing the commonActionProvider. Maybe we can identify what's
>> going wrong.
>> Rahul
>>> assumed would retarget the Open action in the context menu. I get
>>> confused when the author then appends his custom open action to the
>>> "Open Group" of the context menu - why would this need to be done if he
>>> is retargetting the global Open action? I dont want to add a new
>>> action, I want to override the functionality of the existing one.
>>> called when the Open action was selected in the context menu. When I
>>> appended my action to the "Open Group", my action appeared in the
>>> Context menu above the global open action. Is this correct? Again, I
>>> thought my custom action would just get called when the global action
>>> was selected, rather than adding a new action.
>>> tell it only IFile's of a certain Project Nature?
>>> Thanks,
>>> Derek
Re: "Open" menu action in Project Explorer [message #329917 is a reply to message #329901] |
Thu, 10 July 2008 11:10   |
Rahul,
I added the overrides and nothing changed. However, when I add that as
well as priority="high"> or priority="higher">, it does work...not sure
why this is, but it works.
Also, when I say "it works", I mean both the Open and Open With menu
actions are replaced by my custom open action. This is not what I
expected though - I want the context menu to contain my custom open action
and the Open With action. Basically I just want to just retarget the Open
action and nothing else... is this possible or do I have to retarget the
Open With action as well?
Thanks much for the help,
Derek
> and id... so:
> <actionProvider
> class="..."
> id="....."
> Rahul
>> <actionProvider
>> <enablement>
>> <and>
>> <instanceof
>> </instanceof>
>> <test
>> </test>
>> </and>
>> </enablement>
>> </actionProvider>
>> </extension>
>> <includes>
>> <actionExtension
>> </actionExtension>
>> </includes>
>> </extension>
>> m_openAction);
>> Thanks,
>> Derek
>>> <enablement>
>>> <or>
>>> <and>
>>> <test
>>> value="">
>>> </test>
>>> </and>
>>> </or>
>>> </enablement>
>>> going wrong.
>>> Rahul
>>>> Thanks,
>>>> Derek
Re: "Open" menu action in Project Explorer [message #329946 is a reply to message #329917] |
Fri, 11 July 2008 02:56   |
Hi Derek,
Right the priority needs to be set to "high" as well so basically your
extension gets the highest priority over other navigator content extensions
made by other plug-ins.
When you override the Open action you are going to override the "Open With"
action/menu as well. I think you might have to provide your own alternative
implementation for "Open With" or you could leverage the existing code for
"Open With.." menu and add that as your alternative implementation.
I am not sure if you can retarget "just" the Open action keeping the native
"Open With... " menu. Most probably you can't do that but just to confirm
maybe you can put a post again in this group with CNF and override Open
action in the Subject line. Someone more experienced might help you out.
Rahul
news:4c76f0d516c2eca0fea17bcefe8ba0ec$1@www.eclipse.org...
> Rahul,
> Derek
>> class and id... so:
>> <actionProvider
>> class="..."
>> id="....."
>> Rahul
>>> <actionProvider
>>> <enablement>
>>> <and>
>>> <instanceof
>>> </instanceof>
>>> <test
>>> </test>
>>> </and>
>>> </enablement>
>>> </actionProvider>
>>> </extension>
>>> <includes>
>>> <actionExtension
>>> </actionExtension>
>>> </includes>
>>> </extension>
>>> snippet of my commonActionProvider:
>>> m_openAction);
>>> m_openAction);
>>> Thanks,
>>> Derek
>>>> <enablement>
>>>> <or>
>>>> <and>
>>>> <test
>>>> value="">
>>>> </test>
>>>> </and>
>>>> </or>
>>>> </enablement>
>>>> up, that is not the expected behavior. Can you post code from your
>>>> plugin.xml where you have contributed the actionProvider and also
>>>> snippets from your class implementing the commonActionProvider. Maybe
>>>> we can identify what's going wrong.
>>>> Rahul
>>>>> the author sets the global action handler on the open action, which I
>>>>> he is retargetting the global Open action? I dont want to add a new
>>>>> Thanks,
>>>>> Derek
Re: "Open" menu action in Project Explorer [message #329970 is a reply to message #329946] |
Fri, 11 July 2008 10:30   |
Ah I see. Thank you for all your help Rahul!
Derek
Rahul Kamdar wrote:
> Hi Derek,
> Rahul
>> Rahul,
>> Derek
>>> class and id... so:
>>> <actionProvider
>>> class="..."
>>> id="....."
>>> Rahul
>>>> <actionProvider
>>>> <enablement>
>>>> <and>
>>>> <instanceof
>>>> </instanceof>
>>>> <test
>>>> </test>
>>>> </and>
>>>> </enablement>
>>>> </actionProvider>
>>>> </extension>
>>>> <includes>
>>>> <actionExtension
>>>> </actionExtension>
>>>> </includes>
>>>> </extension>
>>>> m_openAction);
>>>> m_openAction);
>>>> Thanks,
>>>> Derek
>>>>> <enablement>
>>>>> <or>
>>>>> <and>
>>>>> <test
>>>>> value="">
>>>>> </test>
>>>>> </and>
>>>>> </or>
>>>>> </enablement>
>>>>> Rahul
>>>>>> Thanks,
>>>>>> Derek
Re: "Open" menu action in Project Explorer [message #330375 is a reply to message #329970] |
Sun, 27 July 2008 06:33   |
I try to do quite the same with "Open" menu action.
But it doesn't work, even I tried to follow the steps in your discussion.
If you have a working solution now, maybe you can provide some piece of
code.
In addition, I need the open action not only for Project Explorer.
Preferable platform-wide.
So is there a chance to provide a "Open" action, if I don't know all
registered views?
What I precisely need is:
When opening a file, then it should use my own editor if the file has a
certain extension (.css) AND it is located in a certain project type( my
own project nature ).
I appreciate any help, thanks.
> Derek
> Rahul Kamdar wrote:
>> Hi Derek,
>> Thanks,
>> Rahul
>>> Rahul,
>>> Derek
>>>> class and id... so:
>>>> <actionProvider
>>>> class="..."
>>>> id="....."
>>>> Rahul
>>>>> <actionProvider
>>>>> <enablement>
>>>>> <and>
>>>>> <instanceof
>>>>> </instanceof>
>>>>> <test
>>>>> </test>
>>>>> </and>
>>>>> </enablement>
>>>>> </actionProvider>
>>>>> </extension>
>>>>> <includes>
>>>>> <actionExtension
>>>>> </actionExtension>
>>>>> </includes>
>>>>> </extension>
>>>>> m_openAction);
>>>>> m_openAction);
>>>>> Thanks,
>>>>> Derek
>>>>>> <enablement>
>>>>>> <or>
>>>>>> <and>
>>>>>> <test
>>>>>> value="">
>>>>>> </test>
>>>>>> </and>
>>>>>> </or>
>>>>>> </enablement>
>>>>>> Rahul
>>>>>>> Thanks,
>>>>>>> Derek
Re: "Open" menu action in Project Explorer [message #330434 is a reply to message #330375] |
Mon, 28 July 2008 15:31  |
Hi Mathias,
What is the problem you are facing while implementing the "Open" menu
action? You could try and describe the problem and post code and maybe we
could tell you what is going wrong.
About the second part of your query/mail - you probably need to make a
change in the "Editor associations" for the filetype. I am not sure if
that's the way to go or even if it is, what's the way to do it. You should
try posting a new post in this group with your query specifically to this
issue.
Rahul
"Mathias Schaeffner" <mathias.schaeffner@googlemail.com> wrote in message
news:d46bca47430a80a59e3ed487952b6408$1@www.eclipsecon.com...
> code.
> registered views?
>> Derek
>> Rahul Kamdar wrote:
>>> Hi Derek,
>>> extensions made by other plug-ins.
>>> With" action/menu as well. I think you might have to provide your own
>>> alternative implementation for "Open With" or you could leverage the
>>> existing code for "Open With.." menu and add that as your alternative
>>> implementation.
>>> native "Open With... " menu. Most probably you can't do that but just to
>>> confirm maybe you can put a post again in this group with CNF and
>>> override Open action in the Subject line. Someone more experienced might
>>> help you out.
>>> Thanks,
>>> Rahul
>>>> Rahul,
>>>> action and the Open With action. Basically I just want to just
>>>> retarget the Open action and nothing else... is this possible or do I
>>>> have to retarget the Open With action as well?
>>>> Derek
>>>>> class and id... so:
>>>>> <actionProvider
>>>>> class="..."
>>>>> id="....."
>>>>> Rahul
>>>>>> <actionProvider
>>>>>> <enablement>
>>>>>> <and>
>>>>>> <instanceof
>>>>>> </instanceof>
>>>>>> <test
>>>>>> </test>
>>>>>> </and>
>>>>>> </enablement>
>>>>>> </actionProvider>
>>>>>> </extension>
>>>>>> <includes>
>>>>>> <actionExtension
>>>>>> </actionExtension>
>>>>>> </includes>
>>>>>> </extension>
>>>>>> my open action along with the global open action, however. Here is a
>>>>>> m_openAction);
>>>>>> m_openAction);
>>>>>> Thanks,
>>>>>> Derek
>>>>>>> <enablement>
>>>>>>> <or>
>>>>>>> <and>
>>>>>>> <test
>>>>>>> value="">
>>>>>>> </test>
>>>>>>> </and>
>>>>>>> </or>
>>>>>>> </enablement>
>>>>>>> coming up, that is not the expected behavior. Can you post code from
>>>>>>> your plugin.xml where you have contributed the actionProvider and
>>>>>>> also snippets from your class implementing the commonActionProvider.
>>>>>>> Maybe we can identify what's going wrong.
>>>>>>> Rahul
>>>>>>>> understand what is supposed to happen from the code in the article
>>>>>>>> are though - the author sets the global action handler on the open
>>>>>>>> action, which I assumed would retarget the Open action in the
>>>>>>>> context menu. I get confused when the author then appends his
>>>>>>>> custom open action to the "Open Group" of the context menu - why
>>>>>>>> would this need to be done if he is retargetting the global Open
>>>>>>>> action? I dont want to add a new action, I want to override the
>>>>>>>> I appended my action to the "Open Group", my action appeared in the
>>>>>>>> Again, I thought my custom action would just get called when the
>>>>>>>> global action was selected, rather than adding a new action.
>>>>>>>> I tell it only IFile's of a certain Project Nature?
>>>>>>>> Thanks,
>>>>>>>> Derek
Current Time: Tue Oct 14 20:39:34 EDT 2025
Powered by FUDForum. Page generated in 0.05353 seconds
