Re: Code that was compiling in 3.3.2 doesn't compile in 3.4 [message #329666 is a reply to message #329664] |
Tue, 01 July 2008 06:44 |
Originally posted by: zx.code9.com
Alon wrote:
> It's happening for me on all the plug-ins in my workspace (7).
> I searched a lot in Bugzilla without success. I thought of opening a
> defect on this because I can't work with 3.4 at all :(
By any chance, are you using link files? If so, check if there aren't
duplicate link files pointing to duplicate directories.
~ Chris
Re: Code that was compiling in 3.3.2 doesn't compile in 3.4 [message #329708 is a reply to message #329664] |
Tue, 01 July 2008 15:34 |
Walter Harley Messages: 847 Registered: July 2009 |
"Alon" <allonr@il.ibm.com> wrote in message
news:ded317995142bc5a40d15b468147623e$1@www.eclipse.org...
"Happening for you on all your plugins" is, sadly, not the same as
"reproducible in a way that others can work on". For a bug report to be
useful, it is not enough to report the problem, you need to find steps that
can let someone else reproduce it. This may be easy, or it may be hard -
ironically, most of the "it doesn't work at all" cases are hard to
reproduce, because obviously for the vast majority of users it *does* work.
If you can start with a fresh workspace and try to figure out the minimal
steps that need to be done to make it show the problem you're experiencing,
that will help. Without that there's not much anyone can do other than be
sympathetic.
Or, hopefully Chris' response will be all you need.
FUDForum. Page generated in 0.04179 seconds
