Home » Archived » Package Drone » Difficulty setting up an example p2 repository
Difficulty setting up an example p2 repository [message #1734309] |
Tue, 07 June 2016 04:20 |
Vadim Peretokin Messages: 45 Registered: July 2009 |
Member |
I've followed the recipe text to create this sample channel (big thanks for providing the easy openshift setup) and I've uploaded my Tycho build to it. Eclipse successfully sees the update site, but it can't download any of the artifacts:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.modeling, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.mdht.cda.xml.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.cda.xml.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.dita.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.dita.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.emf.runtime,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.emf.runtime.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.transform.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.transform.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ant,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ant.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.dita,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.dita.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.resources,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.resources.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.validation,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.validation.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.common.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.edit,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.edit.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.datatypes,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.datatypes.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.rim,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.rim.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.vocab,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.hl7.vocab.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.core,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.core.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.term.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.transform.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.navigator,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.navigator.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.properties,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.properties.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.ui.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.validation,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.validation.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.dita,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.dita.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.fhir.xsd,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.fhir.xsd.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.basic,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.basic.source,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.test,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.cda.test.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.tooling,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.cda.tooling.source,3.0.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml,3.0.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.common,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.common.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.core,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.core.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.edit,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.edit.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.fhir.feature,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.fhir.feature.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.transform,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.transform.source,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.ui,0.5.0.201606070333
No repository found containing: osgi.bundle,org.eclipse.mdht.uml.fhir.ui.source,0.5.0.201606070333
No repository found containing: org.eclipse.update.feature,org.eclipse.mdht.uml.source,3.0.0.201606070333
What could be the problem?
Current Time: Sat May 04 07:25:10 GMT 2024
Powered by FUDForum. Page generated in 0.05233 seconds
