Home » Eclipse Projects » Eclipse Platform » TreeViewer databinding question
TreeViewer databinding question [message #329615] |
Mon, 30 June 2008 05:21  |
I have played with the new ObservableSetTreeContentProvider to add
databinding to our treeviewers. I got my inspiration from a snippet I
found(org.eclipse.jface.examples.databinding.snippets.Snippe t020TreeViewerWithSetFactory.java).
My problem is that in the example all the instances in the tree are of the
same class. Even the input. This makes everything very easy.
The example below is a reworked version of the snippet I went from.
It works with Person objects and it sets the input of the treeviewer to a
Person(which is never shown in the tree). In my case I would like to set
the input of the viewer to an object holding the root person, causing the
Person to be shown in the tree. From what I understand this can only be
achieved by having the two classes, Person and the class holding Person
objects inherit from same baseclass or implement same interface. Am I
missing soemthing here?
Snippet:
package niklas.testbench;
import java.beans.PropertyChangeListener;
import java.beans.PropertyChangeSupport;
import java.util.HashSet;
import java.util.Set;
import org.eclipse.core.databinding.DataBindingContext;
import org.eclipse.core.databinding.beans.BeansObservables;
import org.eclipse.core.databinding.observable.Realm;
import org.eclipse.core.databinding.observable.map.IObservableMap;
import org.eclipse.core.databinding.observable.value.ComputedValue;
import org.eclipse.core.databinding.observable.value.IObservableVal ue;
import org.eclipse.core.databinding.observable.value.WritableValue;
import org.eclipse.jface.databinding.swt.SWTObservables;
import org.eclipse.jface.databinding.viewers.ObservableMapLabelProv ider;
import
org.eclipse.jface.databinding.viewers.ObservableSetTreeConte ntProvider;
import org.eclipse.jface.databinding.viewers.ViewersObservables;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.jface.viewers.ViewerComparator;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.widgets.Tree;
import org.eclipse.swt.widgets.TreeColumn;
import org.eclipse.swt.widgets.TreeItem;
public class FamilyTreeApplication {
private Button pasteButton;
private Button copyButton;
private Shell shell;
private Button addChildPersonButton;
private Button removePersonButton;
private TreeViewer personViewer;
private Tree tree;
private Text personName;
private Text personAge;
private DataBindingContext m_bindingContext;
private Person input = createPerson("no name", "0");
private IObservableValue clipboard;
static int childCounter = 0;
static int ancestorCounter = 0;
* Launch the application
* @param args
Display display = Display.getDefault();
Realm.runWithDefault(SWTObservables.getRealm(display), new Runnable() {
public void run() {
try {
FamilyTreeApplication window = new FamilyTreeApplication();
window.open();
} catch (Exception e) {
e.printStackTrace();
* Open the window
public void open() {
final Display display = Display.getDefault();
createContents();
shell.open();
shell.layout();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
* Create contents of the window
protected void createContents() {
shell = new Shell();
final GridLayout gridLayout_1 = new GridLayout();
gridLayout_1.numColumns = 2;
shell.setLayout(gridLayout_1);
shell.setSize(535, 397);
shell.setText("Family Tree");
final Composite group = new Composite(shell, SWT.NONE);
final RowLayout rowLayout = new RowLayout();
rowLayout.marginTop = 0;
rowLayout.marginRight = 0;
rowLayout.marginLeft = 0;
rowLayout.marginBottom = 0;
rowLayout.pack = false;
group.setLayout(rowLayout);
group
.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false, false,
2, 1));
final Button addRootButton = new Button(group, SWT.NONE);
addRootButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(final SelectionEvent e) {
Set<Person> set = input.getChildren();
Person root = createPerson("Person " + (ancestorCounter++), null);
set.add(root);
input.setChildren(set);
personViewer.setSelection(new StructuredSelection(root));
personName.selectAll();
personName.setFocus();
addRootButton.setText("Add Ancestor");
addChildPersonButton = new Button(group, SWT.NONE);
addChildPersonButton.addSelectionListener(new SelectionAdapter() {
Person parent = getSelectedPerson();
Set<Person> set = new HashSet<Person>(parent.getChildren());
Person child = createPerson("Child " + (childCounter++), null);
set.add(child);
parent.setChildren(set);
addChildPersonButton.setText("Add Child");
removePersonButton = new Button(group, SWT.NONE);
removePersonButton.addSelectionListener(new SelectionAdapter() {
TreeItem selectedItem = personViewer.getTree().getSelection()[0];
Person person = (Person) selectedItem.getData();
TreeItem parentItem = selectedItem.getParentItem();
Person parent;
if (parentItem == null)
parent = input;
else
parent = (Person) parentItem.getData();
set.remove(person);
removePersonButton.setText("Remove");
copyButton = new Button(group, SWT.NONE);
copyButton.addSelectionListener(new SelectionAdapter() {
clipboard.setValue(getSelectedPerson());
copyButton.setText("Copy");
pasteButton = new Button(group, SWT.NONE);
pasteButton.addSelectionListener(new SelectionAdapter() {
Person copy = (Person) clipboard.getValue();
if (copy == null)
return;
if (parent == null)
parent = input;
set.add(copy);
personViewer.setSelection(new StructuredSelection(copy));
pasteButton.setText("Paste");
final Button refreshButton = new Button(group, SWT.NONE);
refreshButton.addSelectionListener(new SelectionAdapter() {
personViewer.refresh();
refreshButton.setText("Refresh");
personViewer = new TreeViewer(shell, SWT.FULL_SELECTION | SWT.BORDER);
final TreeColumn codeColumn = new TreeColumn(personViewer.getTree(),
SWT.NONE);
codeColumn.setWidth(100);
codeColumn.setText("Name"); //$NON-NLS-1$
final TreeColumn codeColumn2 = new TreeColumn(personViewer.getTree(),
SWT.NONE);
codeColumn2.setWidth(100);
codeColumn2.setText("Age"); //$NON-NLS-1$
personViewer.getTree().setHeaderVisible(true);
personViewer.setUseHashlookup(true);
personViewer.setComparator(new ViewerComparator());
tree = personViewer.getTree();
tree.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 2, 1));
final Label nameLabel = new Label(shell, SWT.NONE);
nameLabel.setText("Name");
personName = new Text(shell, SWT.BORDER);
final GridData gd_personName = new GridData(SWT.FILL, SWT.CENTER, true,
false);
personName.setLayoutData(gd_personName);
final Label ageLabel = new Label(shell, SWT.NONE);
ageLabel.setText("Age");
personAge = new Text(shell, SWT.BORDER);
final GridData gd_personAge = new GridData(SWT.FILL, SWT.CENTER, true,
false);
personAge.setLayoutData(gd_personAge);
m_bindingContext = initDataBindings();
initExtraBindings(m_bindingContext);
private static Person createPerson(String name, String age) {
return new Person(name, age);
protected DataBindingContext initDataBindings() {
IObservableValue treeViewerSelectionObserveSelection = ViewersObservables
.observeSingleSelection(personViewer);
IObservableValue nameTextObserveWidget = SWTObservables.observeText(
personName, SWT.Modify);
IObservableValue ageTextObserveWidget = SWTObservables.observeText(
personAge, SWT.Modify);
IObservableValue treeViewerNameValueObserveDetailValue = BeansObservables
.observeDetailValue(Realm.getDefault(),
treeViewerSelectionObserveSelection,
Person.NAME_PROPERTY, java.lang.String.class);
IObservableValue treeViewerAgeValueObserveDetailValue = BeansObservables
Person.AGE_PROPERTY, java.lang.String.class);
DataBindingContext bindingContext = new DataBindingContext();
bindingContext.bindValue(nameTextObserveWidget,
treeViewerNameValueObserveDetailValue, null, null);
bindingContext.bindValue(ageTextObserveWidget,
treeViewerAgeValueObserveDetailValue, null, null);
return bindingContext;
private Person getSelectedPerson() {
IStructuredSelection selection = (IStructuredSelection) personViewer
.getSelection();
if (selection.isEmpty())
return null;
return (Person) selection.getFirstElement();
private void initExtraBindings(DataBindingContext dbc) {
final IObservableValue personViewerSelection = ViewersObservables
IObservableValue personSelected = new ComputedValue(Boolean.TYPE) {
protected Object calculate() {
return Boolean
.valueOf(personViewerSelection.getValue() != null);
dbc.bindValue(SWTObservables.observeEnabled(addChildPersonBu tton),
personSelected, null, null);
dbc.bindValue(SWTObservables.observeEnabled(removePersonButt on),
clipboard = new WritableValue();
dbc.bindValue(SWTObservables.observeEnabled(copyButton),
dbc.bindValue(SWTObservables.observeEnabled(pasteButton),
return Boolean.valueOf(clipboard.getValue() != null);
}, null, null);
bindTree(personViewer,"children",Person.class, new
String[]{Person.NAME_PROPERTY, Person.AGE_PROPERTY});
personViewer.setInput(input);
private void bindTree(TreeViewer viewer, String childrenProperty, Class
childrenClass, String[] propertyNames) {
ObservableSetTreeContentProvider contentProvider = new
ObservableSetTreeContentProvider(
BeansObservables.setFactory(Realm.getDefault(), childrenProperty,
childrenClass), null);
viewer.setContentProvider(contentProvider);
IObservableMap[] viewerLabelProviderMaps = BeansObservables
.observeMaps(contentProvider.getKnownElements(), childrenClass,
propertyNames);
viewer.setLabelProvider(new ObservableMapLabelProvider(
viewerLabelProviderMaps));
static class Person {
public static final String AGE_PROPERTY = "age";
public static final String NAME_PROPERTY = "name";
/* package */PropertyChangeSupport changeSupport = new
PropertyChangeSupport(
this);
private String personName;
private String personAge;
private Set<Person> children;
public Person(String name, String age) {
this.personName = name;
this.personAge = age == null ? "0" : age;
children = new HashSet<Person>();
public void addPropertyChangeListener(PropertyChangeListener listener) {
changeSupport.addPropertyChangeListener(listener);
public void removePropertyChangeListener(PropertyChangeListener
listener) {
changeSupport.removePropertyChangeListener(listener);
public String getName() {
return personName;
public void setName(String value) {
changeSupport.firePropertyChange(NAME_PROPERTY, this.personName,
this.personName = value);
public String getAge() {
return personAge;
public void setAge(String value) {
changeSupport.firePropertyChange(AGE_PROPERTY, this.personAge,
this.personAge = value);
public Set<Person> getChildren() {
if (children == null)
return null;
return new HashSet<Person>(children);
public void setChildren(Set<Person> set) {
if (set != null)
set = new HashSet<Person>(set);
changeSupport.firePropertyChange("children", this.children,
this.children = set);
public boolean hasListeners(String propertyName) {
return changeSupport.hasListeners(propertyName);
Re: TreeViewer databinding question [message #329618 is a reply to message #329615] |
Mon, 30 June 2008 05:45   |
No you aren't. This question and problem has arisen also last week (see
the EMF-Newsgroup for a discussion about this) where we (me and others
trying to adopt this new support) encountered this "shortcoming" of the
TreeSupport.
The problem is two fold:
- ObservableMap & ObservableMapLabelProvider naturally assume that all
objects passed in hold the attributes defined which is for trees not
always correct
- The value one sets as an input get's part of the knowElements-map and
hence passed to the ObservableMap. This is the biggest problem as far
as I can tell currently although support for different ObservableMaps
for different tree-levels would also make the whole thing more usable
Tom
> the same class. Even the input. This makes everything very easy. The
> a Person(which is never shown in the tree). In my case I would like to
> set the input of the viewer to an object holding the root person,
> causing the Person to be shown in the tree. From what I understand this
> can only be achieved by having the two classes, Person and the class
> holding Person objects inherit from same baseclass or implement same
> interface. Am I missing soemthing here?
> Snippet:
> import
> import org.eclipse.swt.widgets.Display;
> private Tree tree;
> * * @param args
> public static void main(String[] args) {
> Runnable() {
> public void run() {
> try {
> window.open();
> * Open the window
> createContents();
> shell.open();
> shell.layout();
> display.sleep();
> group
> false,
> 2, 1));
> @Override
> set.add(root);
> @Override
> null);
> set.add(child);
> @Override
> Person parent;
> parent = input;
> else
> set.remove(person);
> @Override
> @Override
> if (copy == null)
> return;
> if (parent == null)
> parent = input;
> set.add(copy);
> @Override
> SWT.BORDER);
> SWT.NONE);
> SWT.NONE);
> 2, 1));
> SWT.CENTER, true,
> false);
> true,
> false);
> ViewersObservables
> BeansObservables
> BeansObservables
> personViewer
> .getSelection();
> return null;
> @Override
> return Boolean
> @Override
> null);
> }, null, null);
> Class childrenClass, String[] propertyNames) {
> childrenProperty,
> childrenClass,
> propertyNames);
> this);
> listener) {
> listener) {
> return personName;
> this.personName,
> return personAge;
> return null;
> if (set != null)
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: TreeViewer databinding question [message #329809 is a reply to message #329618] |
Sat, 05 July 2008 16:18  |
> always correct
The current (beans, pojo, and EMF) implementations of ObservableMap make
this assumption. You could implement your own... (and contribute it back)
I believe this was fixed very recently, for 3.4.1 and 3.5.
Boris
Current Time: Sat Oct 18 03:39:24 EDT 2025
Powered by FUDForum. Page generated in 0.06242 seconds
