3.4 .link files under OS-X 10.5.3 [message #329610] |
Mon, 30 June 2008 06:55 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: post.peter-jacobsen.de
Did anybody get .link files to work under OS-X 10.5.3? I tried .link
files in the "dropins" and "links" folder but Eclipse does not recognize
the plugins. Creating a symbolic link in the dropins folder (using the
path=/blah... section from the link file) to the plugin directory works
- so the path is correct, but I'd rather use .link files. Any ideas?
Peter
Re: 3.4 .link files under OS-X 10.5.3 [message #329623 is a reply to message #329610] |
Mon, 30 June 2008 13:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I'm not sure .link files are still supported with p2. Read up on it
here: http://wiki.eclipse.org/Equinox_p2_Getting_Started
Hope this helps,
Eric
Re: 3.4 .link files under OS-X 10.5.3 [message #329628 is a reply to message #329623] |
Mon, 30 June 2008 16:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Eric,
the documentation says it should work - the "dropins" folder supports
plugin stuctures direcly and .link files, the "links" folder is kept for
backwards compatibility.
Did anybody get it to work under OS-X 10.5.3?
Peter
>> recognize the plugins. Creating a symbolic link in the dropins folder
>> (using the path=/blah... section from the link file) to the plugin
>> directory works - so the path is correct, but I'd rather use .link
>> files. Any ideas?
> Hope this helps,
> Eric
Re: 3.4 .link files under OS-X 10.5.3 [message #329634 is a reply to message #329628] |
Mon, 30 June 2008 18:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ekkehard.gentz-software.de
for me it works both:
dropins/foo/eclipse/plugins
dropins/foo.link
the .link file contains
path=/your_path
osx 10.5.3
ekke
Peter Jacobsen schrieb:
> Eric,
> Peter
>>> files. Any ideas?
>> Hope this helps,
>> Eric
Re: 3.4 .link files under OS-X 10.5.3 [message #329648 is a reply to message #329634] |
Mon, 30 June 2008 20:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hmmm - for me in the dropins folder only installed plugins or symbolic
links to a plugin folder structure work.
For example my jseclipse.link looks like this:
path=/Users/peter/eclipse-plugins/jseclipse
Directory structure:
/Users/peter/eclipse-plugins/jseclipse/eclipse/plugins
/features
I assume this is correct?
Peter
> dropins/foo.link
> path=/your_path
> osx 10.5.3
> ekke
>> Eric,
>> for backwards compatibility.
>> Thanks,
>> Peter
>>>> folder (using the path=/blah... section from the link file) to the
>>>> plugin directory works - so the path is correct, but I'd rather use
>>> Hope this helps,
>>> Eric
Re: 3.4 .link files under OS-X 10.5.3 [message #329650 is a reply to message #329648] |
Mon, 30 June 2008 21:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
yes - this is correct and exactly the same structure as mine
if you copy
jseclipse/eclipse/plugins + / features
directly into your dropins folder - then it works ?
ekke
> /features
> Peter
>> dropins/foo.link
>> path=/your_path
>> osx 10.5.3
>> ekke
>>> Eric,
>>> Thanks,
>>> Peter
>>>>> .link files in the "dropins" and "links" folder but Eclipse does
>>>>> not recognize the plugins. Creating a symbolic link in the dropins
>>>> Hope this helps,
>>>> Eric
Re: 3.4 .link files under OS-X 10.5.3 [message #329706 is a reply to message #329650] |
Tue, 01 July 2008 13:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi ekke - yes, either copying or creating a symbolic link works. I set
the dropins folder to 0777 because I do not work as administrator on
OS-X. Really strange.
Peter
> if you copy
> ekke
>> /features
>> Peter
>>> dropins/foo.link
>>> path=/your_path
>>> osx 10.5.3
>>> ekke
>>>> Eric,
>>>> supports plugin stuctures direcly and .link files, the "links"
>>>> folder is kept for backwards compatibility.
>>>> Thanks,
>>>> Peter
>>>>> Hope this helps,
>>>>> Eric
Re: 3.4 .link files under OS-X 10.5.3 [message #329707 is a reply to message #329706] |
Tue, 01 July 2008 14:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
perhaps thats the only difference - I'm working as administrator
ekke
> Peter
>> if you copy
>> ekke
>>> symbolic links to a plugin folder structure work.
>>> /features
>>> Peter
>>>> dropins/foo.link
>>>> path=/your_path
>>>> osx 10.5.3
>>>> ekke
>>>>> Eric,
>>>>> Thanks,
>>>>> Peter
>>>>>>> dropins folder (using the path=/blah... section from the link
>>>>>>> file) to the plugin directory works - so the path is correct, but
>>>>>> it here: http://wiki.eclipse.org/Equinox_p2_Getting_Started
>>>>>> Hope this helps,
>>>>>> Eric
FUDForum. Page generated in 0.04780 seconds
