Home » Eclipse Projects » Eclipse Platform » Adding button to Right Click menu
Adding button to Right Click menu [message #329559] Fri, 27 June 2008 15:44 Go to next message
Originally posted by: maxipower_q.yahoo.com
i'm developing a file renamer plugin.
currently, i put a button under 'Edit' menu, on the upper menu of the
Eclipse window. this button opens my GUI. also i use a JFileChooser in my
GUI to take the choosen file's path.
but this is a really bad solution.
i wanna learn;
1. how can i add my plugin's button inside the right click menu in Eclipse?
so user can right click on the file and select it.
(can you tell me what changes should i make in my plugin.xml (shown below))
2. how can i get the choosen file's path to a string? (with which
commands?)
my current plugin.xml file is like that:
<plugin>
<extension point="org.eclipse.ui.actionSets">
<actionSet label="Sample Action Set" visible="true"
id="argela.plugins.rename13.actionSet">
<action label="&Rename13"
class="argela.plugins.rename13.actions.Application"
menubarPath="Edit/Rename13"
id="argela.plugins.rename13.actions.Application">
</action>
</actionSet>
</extension>
</plugin>
Re: Adding button to Right Click menu [message #329573 is a reply to message #329559] Sat, 28 June 2008 07:18 Go to previous messageGo to next message
Do you want to override the existing "Rename" action? Or do you want to
contribute your own form of a rename action which would exist along with the
native "Rename"?
For contributing to the right-click menu (context menu/popup menu) for any
selected resource in the Navigator/Project Explorer view, you can refer to
the articles at:
http://scribbledideas.blogspot.com/2006/06/building-common-n avigator-based-viewer.html
(for using the popupMenus extension point) and
http://scribbledideas.blogspot.com/2006/06/building-common-n avigator-_115067357450703178.html
(actionProviders).
You want to convert the file's path to a string? The IPath/Path class has
couple of API methods for converting into a string of your requirement
(refer javadoc - toPortableString/toOsString etc.).
Rahul
"Cumhur Kilic" <maxipower_q@yahoo.com> wrote in message
news:82a9993aa10179af3f10747e908bd4cf$1@www.eclipse.org...
> i wanna learn;
> Eclipse?
> below))
> commands?)
> <plugin>
> </action>
> </actionSet>
> </extension>
> </plugin>
Re: Adding button to Right Click menu [message #329577 is a reply to message #329573] Sat, 28 June 2008 07:21 Go to previous message
Also, I missed this:
http://scribbledideas.blogspot.com/2006/06/building-common-n avigator-based-viewer_18.html
Your case probably might be better suited to use Object Contributions.
Rahul
"Rahul Kamdar" <rtkamdar@kamdars-india.com> wrote in message
news:g456nc$gu7$1@build.eclipse.org...
> the native "Rename"?
> the articles at:
> (actionProviders).
> Rahul
>> i wanna learn;
>> Eclipse?
>> below))
>> commands?)
>> <plugin>
>> </action>
>> </actionSet>
>> </extension>
>> </plugin>
Previous Topic:Textfield with auto-completion
Next Topic:Re: Eclipse for Vista 64-bit
Current Time: Fri Mar 14 01:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.05024 seconds
