Home » Eclipse Projects » Eclipse Platform » Folding a list
Folding a list [message #329520] Thu, 26 June 2008 15:27 Go to next message
Originally posted by: prasad.chand.gmail.com
Hi all,
I need to fold a list (jface - ListViewer). I had searched and I came
across org.eclipse.jface.text.source.projection that enables folding a
text. But is there anything similar for listviewers? Is there any other
way to implement this in listviewer?
Prasad
Re: Folding a list [message #329536 is a reply to message #329520] Fri, 27 June 2008 08:07 Go to previous messageGo to next message
Prasad Chand wrote:
> Hi all,
Fold a list in what way? Could you use a TreeViewer and put the things
to be folded into different categories (make a 2 level tree, as it were)?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Folding a list [message #329549 is a reply to message #329536] Fri, 27 June 2008 12:37 Go to previous messageGo to next message
What I mean by folding a list is I would like to make the contents (the
individual list entries) disappear.
Yes TreeViewer is a good idea. I have a couple of lists that I wish to
fold. I can use a treeviewer to make the list entries child of a list head.
Thanks for the tip.
Prasad
Paul Webster wrote:
> Prasad Chand wrote:
>> Hi all,
>> other way to implement this in listviewer?
> PW
Re: Folding a list [message #329551 is a reply to message #329536] Fri, 27 June 2008 13:17 Go to previous messageGo to next message
I am facing a problem accomplishing this using TreeViewer. I have three
different entities , a list and two tables. I would like to make them
collapsible - by this I mean I would like to make their contents
disappear on clicking leaving only the list/table label name. As the
"children" are not homogeneous TreeViewer seems off the list.
How can I accomplish this? In swing there is collapsible pane to achieve
it? Is there anything in eclipse/swt/jface to get this done?
Prasad
Paul Webster wrote:
> Prasad Chand wrote:
>> Hi all,
> PW
Re: Folding a list [message #329556 is a reply to message #329551] Fri, 27 June 2008 14:25 Go to previous message
See a org.eclipse.ui.forms.widgets.Twistie which I believe is in
org.eclipse.ui.forms. This can be used to get the Twistie behaviour,
like you see on the Java>Compiler preference pages.
PW
Paul Webster
Previous Topic:perspective Shortcut
Next Topic:Project.create out side workspace
Current Time: Wed Apr 16 11:06:10 EDT 2025
Powered by FUDForum. Page generated in 0.29864 seconds
