Activating a plug-in [message #329465] |
Wed, 25 June 2008 12:23 |
Originally posted by: selcuksumer.hotmail.com
i was working on a plug-in project, i finished coding and Exported it.
now i have the .Jar file, and it works fine in my computer (eclipse 3.3.2).
but when i copy the .jar to another (eclipse 3.3.0) computer's
Eclipse/plugins directory, open Eclipse and try opening the plugin,
eclipse says that it is not available.
is it because of the build.project.xml file ?
should i add this file inside .jar ?
or is it because i should export again and again for every different
computer?
or is it because of the difference in versions?
Thanks..
Re: Activating a plug-in [message #329489 is a reply to message #329479] |
Thu, 26 June 2008 05:56 |
At first, i couldn't get the error log, it was working fine and i wasn't
able to get it from other computers.
now i read the file ;
i quess the problem is the JRE version mismatch.
if you think there are more problems, please let me know.
java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:252)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:248)
org.eclipse.ui.internal.PluginAction.createDelegate(PluginAc tion.java:122)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:228)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown
Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
Re: Activating a plug-in [message #329499 is a reply to message #329489] |
Thu, 26 June 2008 08:36 |
Originally posted by: selcuksumer.yahoo.com
i changed my Development Kit 6 to 5.
so it works fine now.
but of course, i don't know will it work with some other versions.
Re: Activating a plug-in [message #329507 is a reply to message #329499] |
Thu, 26 June 2008 13:16 |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
That error is due to Java JDK differences. Java is upward compatible, so
something compiled at Java 5 will run in Java 6, but something compiled
in Java 6 will not run in Java 5.
So Java 5 will not run in Java 1.4, but unless you need to support Java
1.4 (which is very down level these days), then Java 5 is sufficient.
Unless you need something from 6, then you'll need to pre-req 6 instead.
Rich Kulp
FUDForum. Page generated in 0.05255 seconds
