Home » Eclipse Projects » Eclipse Platform » Toolbar and Menu action work differently
Toolbar and Menu action work differently [message #329449] Tue, 24 June 2008 16:55 Go to next message
Originally posted by: spbgamer.yahoo.com
I have an action defined in my plugin.xml like this:
<action
class="someclass"
helpContextId="contextId"
icon="images/image.gif"
id="action1"
label="action label"
menubarPath="mainMenu/slot2"
style="pulldown"
toolbarPath="MyToolBar"
tooltip="tooltip">
<selection
name="*"
class="org.eclipse.core.resources.IResource">
</selection>
</action>
The action shows up just fine in the toolbar and in the menu. The toolbar
icon has the drop down arrow next to it and it gets populated by the
getMenu() method in someclass. The action in the menu has the submenu
arrow next to it. But, when I pass over my action in the menu the submenu
is not displayed. The getMenu() method in someclass is not called.
Am I doing something wrong? How does the submenu get populated?
Shouldn't getMenu() be called in this instance as well?
Steve
Re: Toolbar and Menu action work differently [message #329472 is a reply to message #329449] Wed, 25 June 2008 10:20 Go to previous messageGo to next message
Do you implement org.eclipse.ui.IWorkbenchWindowPulldownDelegate2? Does
it work at all if you don't include the toolbarPath (simply make it a
menu item)?
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Re: Toolbar and Menu action work differently [message #329485 is a reply to message #329472] Wed, 25 June 2008 16:40 Go to previous messageGo to next message
Paul,
No, I did not implement org.eclipse.ui.IWorkbenchWindowPulldownDelegate2,
only org.eclipse.ui.IWorkbenchWindowPulldownDelegate. After implementing
IWorkbenchWindowPulldownDelegate2, my getMenu(Menu arg0) method is called
and the submenu is created. Thanks a lot. It seems that getMenu(Menu
arg0) is only called the first time I access the submenu, though. I need
to dynamically build the submenu contents based on artifacts in my
project. The action is similar to an "Open" action. The submenu should
list the artifacts in my project that the action can open. You can add
and remove these artifacts, thus making the submenu contents dynamic. Is
this a limitation of the submenu? I tried it with the action included in
the toolbar and menu and then with the action just contained in the menu.
getMenu(Menu arg0) was only called once in both cases.
Thanks again for the reply. I don't think I would have thought of
IWorkbenchWindowPulldownDelegate2 without your help.
Steve
Re: Toolbar and Menu action work differently [message #329517 is a reply to message #329485] Thu, 26 June 2008 13:56 Go to previous message
"Dynamicness" in SWT involves adding a SWT event listener on SWT.Show
(or one of the MenuListeners) so that you can dispose and recreate the
MenuItems that you need.
PW
Paul Webster
Previous Topic:Show next page after finish button was clicked
Next Topic:TabbedPropertyList
Current Time: Fri Oct 17 09:24:03 EDT 2025
Powered by FUDForum. Page generated in 0.05559 seconds
