| Launching exported product in 3.4RC3 [message #329361] |
Fri, 20 June 2008 21:10  |
Originally posted by: automatic.javalobby.org
I've updated to 3.4 rc3 & am now getting an error when trying to run the exported product:
<code>
!SESSION 2008-06-21 12:45:19.539 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_15
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_NZ
Command-line arguments: -os win32 -ws win32 -arch x86 -consoleLog -console
!ENTRY org.eclipse.osgi 4 0 2008-06-21 12:45:20.651
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
</code>
The config.ini is automatically generated to:
<code>
#Product Runtime Configuration File
osgi.splashPath=platform:/base/plugins/nz.co.company.energyr econciliation.ui
eclipse.product=nz.co.company.energyreconciliation.ui.produc t
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
osgi.bundles.defaultStartLevel=4
</code>
This worked fine under Eclipse 3.3.2 but now with 3.4rc2, it's not. Any ideas?
Cheers
| Re: Launching exported product in 3.4RC3 [message #329867 is a reply to message #329361] |
Tue, 08 July 2008 15:05   |
Originally posted by: mircea.luchian.matrox.com
Hello Glenn,
I came across your post from June and I still have the same problem with
Eclipse 3.4 (final build). Did you find a solution to your problem?
Mircea
Glenn Gilbert wrote:
> <code>
> !STACK 1
> </code>
> <code>
> </code>
> Cheers
FUDForum. Page generated in 0.04745 seconds
