Launching exported product in 3.4RC3 [message #329361] |
Sat, 21 June 2008 01:10 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: automatic.javalobby.org
I've updated to 3.4 rc3 & am now getting an error when trying to run the exported product:
<code>
!SESSION 2008-06-21 12:45:19.539 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.5.0_15
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_NZ
Command-line arguments: -os win32 -ws win32 -arch x86 -consoleLog -console
!ENTRY org.eclipse.osgi 4 0 2008-06-21 12:45:20.651
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
</code>
The config.ini is automatically generated to:
<code>
#Product Runtime Configuration File
osgi.splashPath=platform:/base/plugins/nz.co.company.energyr econciliation.ui
eclipse.product=nz.co.company.energyreconciliation.ui.produc t
osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start
osgi.bundles.defaultStartLevel=4
</code>
This worked fine under Eclipse 3.3.2 but now with 3.4rc2, it's not. Any ideas?
Cheers
Re: Launching exported product in 3.4RC3 [message #329867 is a reply to message #329361] |
Tue, 08 July 2008 19:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mircea.luchian.matrox.com
Hello Glenn,
I came across your post from June and I still have the same problem with
Eclipse 3.4 (final build). Did you find a solution to your problem?
Mircea
Glenn Gilbert wrote:
> <code>
> !STACK 1
> </code>
> <code>
> </code>
> Cheers
Re: Launching exported product in 3.4RC3 [message #329888 is a reply to message #329875] |
Wed, 09 July 2008 14:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Glenn,
I found a workaround. I wrote a bugzilla :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=240084
It's a bug on the Eclipse side and the workaround is explained there.
Just copy the missing parameters from your osgi_bundles line generated
in 3.3 to your 3.4 config.ini and it should work.
Mircea
> Hi Mircea,
> I've got a lot on, so I reverted the target platform to 3.3 until I get time to sort it. Keep an eye out. I'll post when I get it sorted.
FUDForum. Page generated in 0.02951 seconds
