Re: Possible to build an update site from 3.2 for 3.4? [message #329405 is a reply to message #329360] |
Mon, 23 June 2008 12:52 |
Farokh Morshed wrote:
> Is it possible to build an update site from 3.3 such that when
> installing it into 3.4 you don't have to go through the old update manager?
The new p2 update mechanism can handle the old update site format, so
you don't really have to change it to accommodate 3.4 users. However,
the p2 team seems to strongly recommend that you move to the new format
because apparently p2 is a lot more efficient that way.
All the info you need is probably available from here:
http://wiki.eclipse.org/Equinox_p2
Hope this helps,
Eric
Re: Possible to build an update site from 3.2 for 3.4? [message #329414 is a reply to message #329405] |
Mon, 23 June 2008 14:50 |
>> manager?
To be clear, the "new format" adds some extra files to the site, but
doesn't alter the existing site.xml or other files. Thus a p2 repository
and Update Manager site can coexist at the same URL.
FUDForum. Page generated in 0.03995 seconds
