Problem with jar included twice [message #329355] |
Fri, 20 June 2008 17:47 |
David![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=davidmmx81-eclipse%40yahoo.es) Messages: 3 Registered: July 2009 |
Junior Member |
Hi, I've been developing a plugin and all was (almost) smooth until I
tried to deploy it. My plugin includes (uses) log4j and commons logging,
but it's not intended to run alone... it depends on other plugins which
you most likely don't know aboute (just in case, I'll mention they are
part of the Neon Toolkit). The problem is, if I don't include the jar
package of the commons.logging then I get this message (from the log file):
!ENTRY org.eclipse.osgi 4 0 2008-06-20 19:33:44.218
!MESSAGE An error occurred while automatically activating bundle
org.neontoolkit.oyster2.client.gui (200).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.neontoolkit.oyster2.client.gui.Activator.start() of bundle
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1010)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:342)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:88)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:412)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:334)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:278)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:172)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:625)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:219)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:125)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1487)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:950)
at org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:941)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:3408)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:3406)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:92)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:336)
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:352)
org.eclipse.ui.actions.PerspectiveMenu$3.runWithEvent(Perspe ctiveMenu.java:108)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Caused by: java.lang.NoClassDefFoundError: org/apache/commons/logging/Log
org.neontoolkit.oyster2.client.gui.WebServersLocator.<init>(WebServersLocator.java:47)
at org.neontoolkit.oyster2.client.gui.Activator.start(Activator .java:51)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
... 58 more
Root exception:
Fine, that was to be expected when omitting a jar file. But if I include
it, the first time I open my perspective it works, but if I close Eclipse
and starts it again, this happens (pay attention to the last line):
!ENTRY com.ontoprise.ontostudio.datamodel 4 0 2008-06-20 19:42:04.296
!MESSAGE java.lang.ExceptionInInitializerError
!STACK 0
org.springframework.core.io.DefaultResourceLoader.<init>(DefaultResourceLoader.java:52)
org.springframework.context.support.AbstractApplicationConte xt. <init>(AbstractApplicationContext.java:184)
org.springframework.context.support.AbstractApplicationConte xt. <init>(AbstractApplicationContext.java:177)
org.springframework.context.support.GenericApplicationContex t. <init>(GenericApplicationContext.java:97)
org.springframework.context.support.GenericApplicationContex t. <init>(GenericApplicationContext.java:119)
org.springframework.context.support.StaticApplicationContext . <init>(StaticApplicationContext.java:63)
org.springframework.context.support.StaticApplicationContext . <init>(StaticApplicationContext.java:52)
at com.ontoprise.indexer.IndexManager.a(IndexManager.java:67)
at com.ontoprise.indexer.IndexManager.<init>(IndexManager.java:49)
com.ontoprise.apibase.OntoBrokerOntologyManagerCore.b(OntoBr okerOntologyManagerCore.java:395)
com.ontoprise.apibase.OntoBrokerOntologyManagerCore.<init>(OntoBrokerOntologyManagerCore.java:105)
org.semanticweb.kaon2.api.KAON2Manager.newOntologyManager(KA ON2Manager.java:133)
com.ontoprise.ontostudio.datamodel.impl.ModuleContainer.conn ect(ModuleContainer.java:305)
com.ontoprise.ontostudio.datamodel.impl.ModuleContainer.<init >(ModuleContainer.java:197)
com.ontoprise.ontostudio.datamodel.DatamodelPlugin.createCon tainer(DatamodelPlugin.java:459)
com.ontoprise.ontostudio.datamodel.DatamodelPlugin.getContai ner(DatamodelPlugin.java:325)
com.ontoprise.ontostudio.io.actions.RestoreRunnable.run(Rest oreRunnable.java:65)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Caused by: org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: Invalid class loader
hierarchy. You have more than one version of
'org.apache.commons.logging.Log' visible, which is not allowed. (Caused by
'org.apache.commons.logging.Log' visible, which is not allowed.) (Caused
by org.apache.commons.logging.LogConfigurationException:
'org.apache.commons.logging.Log' visible, which is not allowed.))
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:543)
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:235)
org.apache.commons.logging.impl.LogFactoryImpl.getInstance(L ogFactoryImpl.java:209)
at org.apache.commons.logging.LogFactory.getLog(LogFactory.java :351)
at org.springframework.util.ClassUtils.<clinit>(ClassUtils.java:72)
... 18 more
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:397)
org.apache.commons.logging.impl.LogFactoryImpl.newInstance(L ogFactoryImpl.java:529)
... 22 more
Caused by: org.apache.commons.logging.LogConfigurationException: Invalid
class loader hierarchy. You have more than one version of
org.apache.commons.logging.impl.LogFactoryImpl.getLogConstru ctor(LogFactoryImpl.java:385)
so, it says:
You have more than one version of 'org.apache.commons.logging.Log'
Well... how can I solve this???
... 23 more
FUDForum. Page generated in 0.02590 seconds
