Home » Eclipse Projects » Eclipse Platform » How to read a file inside a plug-in's folder
How to read a file inside a plug-in's folder [message #329344] Fri, 20 June 2008 03:09 Go to next message
Originally posted by: fbanica.soluta.net
Hello all,
I want to solve the following problem:
- I have a file (whatsnew.txt) which contains a history of updates for every
version of my RCP application
- at the moment, this file is in the application folder (when the
application is deployed) and is read by a BufferedReader (BufferedReader in
= new BufferedReader(new FileReader(pathFile));)
- when I use an update of the features of my application, the features and
plug-in's are updated, but I don't know how to make even the whatsnew.txt
file get updated by this mechanism.
So, I imagined this scenario:
- put the whatsnew.txt file inside the plug-in folder (together with
plugin.xml or plugin.properties, etc.)
- read this file, somehow, and get its content
The problem is: how can I read it, being inside the plug-in folder?
Any hint? Please, help!
Thank you,
Floppy
Re: How to read a file inside a plug-in's folder [message #329345 is a reply to message #329344] Fri, 20 June 2008 03:15 Go to previous messageGo to next message
P.S. In other words, how to read a .txt file from the workspace? It's a .txt
file, not a .properties file...
"Florin Banica" <fbanica@soluta.net> wrote in message
news:g3fl2f$im2$1@build.eclipse.org...
> Hello all,
> every version of my RCP application
> in = new BufferedReader(new FileReader(pathFile));)
> Thank you,
> Floppy
Re: How to read a file inside a plug-in's folder [message #329347 is a reply to message #329345] Fri, 20 June 2008 05:01 Go to previous messageGo to next message
Originally posted by: ali.akar.geensys.com
I think you can use URI.createPlatformPlugin() if ur file is in the
install location and URI.createPlatformResource() if your file is in the
workspace.
hope this help you,
>> Hello all,
>> Thank you,
>> Floppy
Re: How to read a file inside a plug-in's folder [message #329348 is a reply to message #329347] Fri, 20 June 2008 05:45 Go to previous messageGo to next message
Sorry, I don't get it... Do you a have a code snippet? It would be more
meaningful.
Thanks!
"Ali Akar" <ali.akar@geensys.com> wrote in message
news:g3frai$b2o$1@build.eclipse.org...
>I think you can use URI.createPlatformPlugin() if ur file is in the install
>location and URI.createPlatformResource() if your file is in the workspace.
> hope this help you,
> Florin Banica a
Re: How to read a file inside a plug-in's folder [message #329349 is a reply to message #329348] Fri, 20 June 2008 05:59 Go to previous messageGo to next message
Assuming your file is inside the META-INF-Directory
Activator.getDefault().getBundle().getEntry("/META-INF/changelog.txt ").openStream();
> meaningful.
> Thanks!
>> hope this help you,
>>> .txt file, not a .properties file...
>>>> Hello all,
>>>> and plug-in's are updated, but I don't know how to make even the
>>>> whatsnew.txt file get updated by this mechanism.
>>>> Thank you,
>>>> Floppy
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to read a file inside a plug-in's folder [message #329351 is a reply to message #329349] Fri, 20 June 2008 06:22 Go to previous messageGo to next message
Hmmm, I tried that, but it gives me a big
java.lang.NullPointerException... :-(
Do you have any idea why this should happen?
"Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
news:g3fv20$ru5$1@build.eclipse.org...
>> meaningful.
>> Thanks!
>>> workspace.
>>> hope this help you,
>>> Florin Banica a
Re: How to read a file inside a plug-in's folder [message #329352 is a reply to message #329351] Fri, 20 June 2008 06:31 Go to previous message
Ooops, sorry, I misspelled the file name...
It's working fine, thanks again!
news:g3g0cp$2hg$1@build.eclipse.org...
>>> meaningful.
>>> Thanks!
>>>> the workspace.
>>>> hope this help you,
>>>> Florin Banica a crit :
>>>>> a .txt file, not a .properties file...
>>>>>> Hello all,
>>>>>> for every version of my RCP application
>>>>>> (BufferedReader in = new BufferedReader(new FileReader(pathFile));)
>>>>>> features and plug-in's are updated, but I don't know how to make even
>>>>>> the whatsnew.txt file get updated by this mechanism.
>>>>>> Thank you,
>>>>>> Floppy
Previous Topic:platform text: DSL model/document reconciling
Next Topic:[3.4RC4] Disable a plugin installed via dropins
Current Time: Mon Sep 15 12:29:44 EDT 2025
Powered by FUDForum. Page generated in 0.05801 seconds
