Home » Eclipse Projects » Eclipse Platform » [Databinding] Converted values not seen in Text
[Databinding] Converted values not seen in Text [message #329295] |
Wed, 18 June 2008 14:32 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Christoph Jäger![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=christoph.jaeger%40cargodata.at) Messages: 14 Registered: July 2009 |
Junior Member |
I am using Eclipse 3.4RC3.
I have a Text field, which is connected to a String property via data
binding like this:
IObservable observable = ... ; // bound to my String property
Text name=new Text(parent, SWT.NONE);
UpdateValueStrategy targetToModelStrategy=new UpdateValueStrategy();
targetToModelStrategy.setConverter(new TrimWhiteSpaceConverter());
IObservableValue textObserveWidget=SWTObservables.observeText(name,
SWT.FocusOut);
dataBindingContext.bindValue(textObserveWidget, observable,
targetToModelStrategy, null);
This should trim whitespace (leading and trailing) from the value
entered into the Text field.
Now, this works fine for updating the model, when I enter " Test " into
the Text field, the model gets updated with "Test" (note: whitespace
removed).
What does not work: the value in the Text field stays " Test ".
There must be a simple way to make the Text field also be updated with
the value after conversion. Can anyone point me in the right direction?
Christoph Jäger
Re: [Databinding] Converted values not seen in Text [message #329298 is a reply to message #329295] |
Wed, 18 June 2008 14:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thomas Schindl![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=tom.schindl%40bestsolution.at) Messages: 6651 Registered: July 2009 |
You'll need to call do this manually after your model is updated by calling:
Binding#updateModelToTarget()
Tom
Christoph Jaeger schrieb:
> binding like this:
> SWT.FocusOut);
> removed).
> Christoph Jäger
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [Databinding] Converted values not seen in Text [message #329406 is a reply to message #329365] |
Mon, 23 June 2008 12:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Boris Bokowski wrote:
> Could you please file an enhancement request in Bugzilla? This seems to be a
> common feature request that we should support. We could also use the
> Bugzilla to discuss possible workarounds.
Please post the Bugzilla number or link here so other interested readers
can follow the progress.
Eric
> "Christoph Jaeger" <christoph.jaeger@cargodata.at> wrote in message
> news:g3b9dr$pm7$1@build.eclipse.org...
>>> calling:
>> Thanks for your hint. So I extended UpdateValueStrategy to override
>> @Override
>> protected IStatus doSet(IObservableValue observableValue, Object value)
>> IStatus status=super.doSet(observableValue, value);
>> if (binding!=null) binding.updateModelToTarget();
>> return status;
>> and make sure I set the binding (see last line):
>> UpdateValueStrategyWithFeedback targetToModelStrategy=new
>> UpdateValueStrategyWithFeedback();
>> Binding binding=dataBindingContext.bindValue(textObserveWidget,
>> observable, targetToModelStrategy, null);
>> targetToModelStrategy.setBinding(binding);
>> Looks a bit strange (first I use the targetModelStrategy to create a
>> binding, and then I feed the resulting binding to the
>> targetModelStrategy), but seems to work. Do I need to worry about
>> disposing the binding instance I pass into targetModelStrategy?
>> Or is there an easier way to achieve the same?
>> Thanks,
>> Christoph
Current Time: Sat Jul 27 12:23:32 GMT 2024
Powered by FUDForum. Page generated in 0.04023 seconds
