Home » Eclipse Projects » Eclipse Platform » How to get IAction from actionSet?
How to get IAction from actionSet? [message #329167] Mon, 16 June 2008 10:22 Go to next message
Drug Vignera is currently offline Drug VigneraFriend
I've developed plugin with extension point org.eclipse.ui.actionSet. It
has class that implements IWorkbenchWindowActionDelegate. How to get
IAction in the constructor of this class?
Re: How to get IAction from actionSet? [message #329172 is a reply to message #329167] Mon, 16 June 2008 12:09 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
You can't ... but if you implement IActionDelegate2 as well you will
have your init(*) method called shortly after construction.
PW
Paul Webster
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:extension points distribution
Next Topic:calling tree during execution
Current Time: Fri Nov 08 21:48:56 GMT 2024
Powered by FUDForum. Page generated in 0.03303 seconds
