Re: Run as ... issue [message #329150 is a reply to message #329148] |
Fri, 13 June 2008 20:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
al wrote:
> The Run as button used to work such that if I just clicked on it, it ran
> the most recently run java application. It doesn't do this anymore. Now,
> to run the most recent application, I have to pull down and select it.
> Can anyone tell me what happened to this functionality?
It was intentionally changed in for 3.3. It is described on this "New &
Noteworthy" page:
http://archive.eclipse.org/eclipse/downloads/drops/R-3.3-200 706251500/whatsnew/eclipse-news-part1.html
Look for the section named "Launch selection vs. launch last" near the
bottom.
The good news is, you can revert to the old behavior by toggling a
preferences setting (also described in the above document).
Hope this helps,
Eric
FUDForum. Page generated in 0.03927 seconds
