databinding number format [message #329124] |
Fri, 13 June 2008 11:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: lukas.myslivec.com
i am useing jface databinding to bind an int attribute of my to a text
field. But the text field formats the int what i dont like.
for example:
int intVal = 2500
the text field shows "2.500".
could that be disabled?
thanks for any help
/lukas
Re: databinding number format [message #329131 is a reply to message #329124] |
Fri, 13 June 2008 14:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
lukas wrote:
> Hello,
> for example:
> int intVal = 2500
Conversion can be overridden in several ways:
1) You can call setConverter() on the UpdateValueStrategy that is passed
in when you call DataBindingContext.bindValue(). However, I think that
will effectively eliminate all of the default conversions; not a problem
if that particular binding only ever binds to integer values in the
model, but if it can be something else, you have to handle all the
potential conversions.
2) You can subclass UpdateValueStrategy and override the method
createConverter() which is called to create the default converter if
none is specified via setConverter(). This might be a better option if
you need to apply the special conversion in multiple places and to
bindings that may not always be converting integer values.
Option 1 is simpler if you know for sure your situation is always
integer <-> Text binding.
Hope this helps,
Eric
FUDForum. Page generated in 0.03109 seconds
