Re: Dynamic icons from file system in plugin [message #329126 is a reply to message #329122] |
Fri, 13 June 2008 11:32 |
Loïc,
What you describe sounds like a really bad idea even if it works. What
does the stack trace look like? If it's a failure in the
URL.openStream itself I kind of doubt it's an Eclipse issue but more
fundamental. I suspect that file:/c:/myicon.gif and
file://c:/myicon.gif are likely to work better...
Loïc Quéran wrote:
> Can a plugin load icons/images from a URL such as
> "file:///c:/myicon.gif" ? The URL.openStream() fails in PDE with an
> UnkownHostException. The same code works in a simple, not plugin, java
> program.
> Any idea ?
> Loïc
Re: Dynamic icons from file system in plugin [message #329129 is a reply to message #329127] |
Fri, 13 June 2008 13:47 |
Loïc,
Did you try what I suggested? It's possible to step into the code to
see what's going on... And besides, you said you saw a failure with
leads me to believe the failure wasn't silent and that there will be a
stack trace in your log...
I thought the URI RFC only talked about the // segment representing the
authority... I think different schemes can interpret the information
there how they like....
(Please try to avoid doing a reply-all so I don't get direct notes to my
e-mail address.)
Loïc Quéran wrote:
> I want to integrate another tool with Eclipse. The other provides
> data, which contains paths to icons which must be displayed in an
> Eclipse TreeViewer.
> The correct url should be file://localhost/c:/myicon.gif. In W3C
> specs, it is written that localhost can be omitted.
> file://c:/myicon.gif works in Firefox, which changes it to
> file:///c:/myicon.gif which also works in Firefox.
> There is no stack trace because ImageDescriptor.getImageData() fails
> silently.
> Ed Merks a écrit :
>> Loïc,
>> What does the stack trace look like? If it's a failure in the
>>> java program.
>>> Any idea ?
>>> Loïc
Re: Dynamic icons from file system in plugin [message #329698 is a reply to message #329129] |
Tue, 01 July 2008 13:10 |
Lo�¯c Qu�©ran Messages: 45 Registered: July 2009 |
Member |
Sorry for my late answer. As usually, you were right, Ed ...
Thanks a lot.
Loïc
Ed Merks a écrit :
> Loïc,
> e-mail address.)
>> Eclipse TreeViewer.
>> silently.
>> Ed Merks a écrit :
>>> Loïc,
>>>> java program.
>>>> Any idea ?
>>>> Loïc
FUDForum. Page generated in 0.05659 seconds
