Eclipse does not run with JRE 1.6.0 [message #329068] |
Wed, 11 June 2008 23:50 |
I recently update my version of JRE to the 1.6.0 version.
But then on i canŽt start the eclipse plataform.
This update is made by the JRE it self so is a big problem for allmost
all users of eclipse.
Bye.
Re: Eclipse does not run with JRE 1.6.0 [message #329069 is a reply to message #329068] |
Thu, 12 June 2008 00:33 |
Camilo,
It almost makes you wonder how it could be possible that no one noticed
that Eclipse simply stops working with 1.6.0...
Which OS are you on? Specifically which JRE level/vendor did you update
too? I.e., if you run it with -version, what does it print? Are there
clues in the <workspace>/.metadata/.log?
> Bye.
FUDForum. Page generated in 0.02900 seconds
