| why eclipse load the old plugin [message #329041] | Wed, 11 June 2008 01:34  |  |
| Eclipse User  |  |  |  |  | Hi, all
 I have two plug-ins with different version, they are: x.y.myPlugin(3.0.0)
 and x.y.myPlugin(4.0.0).
 The problem is that the older one (x.y.myPlugin(3.0.0)) is loaded after
 eclipse started.
 But I think that eclipse manages all the plug-in and their version as well,
 and it should make sure that the newer plug-ins are always loaded.
 Did I missing anything?
 Thanks & Best Regards!
 Nick
| Re: why eclipse load the old plugin [message #329078 is a reply to message #329047] | Thu, 12 June 2008 03:44  |  |
| Eclipse User  |  |  |  |  | Thanks Ed,
 I got it, and it works fine after I set "singleton:=true" for the
 Bundle-SymbolicName of the newer plug-in x.y.myPlugin(4.0.0),
 But what I wandered is that why eclipse active the old one if I did not set
 "singleton:=true" though the two plug-ins are both resolved successfully?
 Nick
 "Ed Merks" <merks@ca.ibm.com> wrote in message
 news:g2o2ur$37r$2@build.eclipse.org...
 > Nick,
 > Try running with -clean -debug and looking at the
 > <workspace>/.metadata/.log. It should describe what plugins are being
 > activated and the details of that will likely help explain. For example,
 > the newer plugin might require things that aren't available or there
 > might be other plugins that specifically require the older version of
 > the plugin, since plugin dependencies can specify ranges...
 > Nick Tan wrote:
 >> Hi, all
 >> x.y.myPlugin(3.0.0) and x.y.myPlugin(4.0.0).
 >> after eclipse started.
 >> well, and it should make sure that the newer plug-ins are always loaded.
 >> Nick
FUDForum. Page generated in 0.04692 seconds
