Re: why eclipse load the old plugin [message #329047 is a reply to message #329041] |
Wed, 11 June 2008 08:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nick,
Try running with -clean -debug and looking at the
<workspace>/.metadata/.log. It should describe what plugins are being
activated and the details of that will likely help explain. For example,
the newer plugin might require things that aren't available or there
might be other plugins that specifically require the older version of
the plugin, since plugin dependencies can specify ranges...
Nick Tan wrote:
> Hi, all
> I have two plug-ins with different version, they are:
> x.y.myPlugin(3.0.0) and x.y.myPlugin(4.0.0).
> The problem is that the older one (x.y.myPlugin(3.0.0)) is loaded
> after eclipse started.
> But I think that eclipse manages all the plug-in and their version as
> well, and it should make sure that the newer plug-ins are always loaded.
> Did I missing anything?
> Thanks & Best Regards!
> Nick
Re: why eclipse load the old plugin [message #329078 is a reply to message #329047] |
Thu, 12 June 2008 07:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
nick tan![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=missedone%40gmail.com) Messages: 56 Registered: July 2009 |
Member |
Thanks Ed,
I got it, and it works fine after I set "singleton:=true" for the
Bundle-SymbolicName of the newer plug-in x.y.myPlugin(4.0.0),
But what I wandered is that why eclipse active the old one if I did not set
"singleton:=true" though the two plug-ins are both resolved successfully?
Nick
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:g2o2ur$37r$2@build.eclipse.org...
> Nick,
> Nick Tan wrote:
>> Hi, all
>> Nick
FUDForum. Page generated in 0.03417 seconds
