Example of use of Annotations with SourceViewer (and not TextEditor) [message #329014] |
Tue, 10 June 2008 10:52 |
The example project is here (run as an Eclipse Application - see the
instructions in SampleEditor.java):
http://www.oaklandsoftware.com/eclipse/sourceviewsample.zip
Here is the main class (for convenience):
package sourceviewsample;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.jface.text.Document;
import org.eclipse.jface.text.IDocument;
import org.eclipse.jface.text.Position;
import org.eclipse.jface.text.source.Annotation;
import org.eclipse.jface.text.source.AnnotationModel;
import org.eclipse.jface.text.source.CompositeRuler;
import org.eclipse.jface.text.source.IOverviewRuler;
import org.eclipse.jface.text.source.ISharedTextColors;
import org.eclipse.jface.text.source.LineNumberRulerColumn;
import org.eclipse.jface.text.source.OverviewRuler;
import org.eclipse.jface.text.source.SourceViewer;
import org.eclipse.jface.text.source.SourceViewerConfiguration;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IEditorSite;
import org.eclipse.ui.PartInitException;
import org.eclipse.ui.internal.editors.text.EditorsPlugin;
import org.eclipse.ui.part.EditorPart;
import org.eclipse.ui.texteditor.AnnotationPreference;
import org.eclipse.ui.texteditor.SourceViewerDecorationSupport;
* An example of using a SourceViewer with Annotation support outside
of the
* TextEditor class. This annotations can be configured in the
preferences if
* the markerAnnotationSpecification is setup in the plugin.xml.
* To execute this, run as an Eclipse Application and then open a file
using
* Open with.. -> Other, and select Sample Editor. You will see the
text that
* comes in this example and the highlight.
public class SampleEditor extends EditorPart
public static final String ANNO_TYPE =
"com.mycompany.element";
public static final String ANNO_KEY_HIGHLIGHT =
"annotateElemHighlight";
public static final String ANNO_KEY_OVERVIEW =
"annotateElemOverviewRuler";
public static final String ANNO_KEY_VERTICAL =
"annotateElemVertialRuler";
public static final String ANNO_KEY_TEXT =
"annotateElemText";
public static final String ANNO_KEY_COLOR =
"annotateElemColor";
protected SourceViewer _sourceViewer;
protected SourceViewerDecorationSupport _sds;
protected IDocument _document;
protected AnnotationModel _annotationModel;
protected String _docString =
"this\nis\na\ntest\ndocument";
public SampleEditor()
super();
public void createPartControl(Composite parent)
int VERTICAL_RULER_WIDTH = 12;
int styles = SWT.V_SCROLL
| SWT.H_SCROLL
| SWT.MULTI
| SWT.BORDER
| SWT.FULL_SELECTION;
ISharedTextColors sharedColors = EditorsPlugin.getDefault()
.getSharedTextColors();
IOverviewRuler overviewRuler = new OverviewRuler(null,
VERTICAL_RULER_WIDTH,
sharedColors);
CompositeRuler ruler = new CompositeRuler(VERTICAL_RULER_WIDTH);
_document = new Document();
_document.set(_docString);
_annotationModel = new AnnotationModel();
_annotationModel.connect(_document);
_sourceViewer = new SourceViewer(parent,
ruler,
overviewRuler,
true,
styles);
_sourceViewer.configure(new SourceViewerConfiguration());
_sds = new SourceViewerDecorationSupport(_sourceViewer,
overviewRuler,
null,
sharedColors);
AnnotationPreference ap = new AnnotationPreference();
ap.setColorPreferenceKey(ANNO_KEY_COLOR);
ap.setHighlightPreferenceKey(ANNO_KEY_HIGHLIGHT);
ap.setVerticalRulerPreferenceKey(ANNO_KEY_VERTICAL);
ap.setOverviewRulerPreferenceKey(ANNO_KEY_OVERVIEW);
ap.setTextPreferenceKey(ANNO_KEY_TEXT);
ap.setAnnotationType(ANNO_TYPE);
_sds.setAnnotationPreference(ap);
_sds.install(EditorsPlugin.getDefault().getPreferenceStore() );
_sourceViewer.setDocument(_document, _annotationModel);
_sourceViewer.getControl().setLayoutData(new GridData(SWT.FILL,
SWT.FILL,
true,
true));
ruler.addDecorator(0, new LineNumberRulerColumn());
Annotation annotation = new Annotation(false);
annotation.setType(ANNO_TYPE);
Position position = new Position(0, 4);
_annotationModel.addAnnotation(annotation, position);
public void dispose()
// The _sourceViewer goes away automatically when the editor goes
// away because it's hooked to the controls
_sds.dispose();
// This stuff below is just needed to make the EditorPart happy
public void doSave(IProgressMonitor monitor)
public void doSaveAs()
public void init(IEditorSite site, IEditorInput input)
throws PartInitException
setSite(site);
setInput(input);
public boolean isDirty()
return false;
public boolean isSaveAsAllowed()
return false;
public void setFocus()
FUDForum. Page generated in 0.03089 seconds
